Question about Goodman CKL36AR36 Air Conditioner
BLOWS FUSES EVERYTIME I TURN AIR ON
EVERYTIME I TURN THE AIR ON THE FUSE BLOWS
    Problem Solver:
  • 5 Answers
Do you have a 38 shot gun? i only ask because it may be time to get it loaded. the most common cuase of fuses tripping is your compressor. going to ground. before you shoot it you should inspect the 3 wires connected to the compressor to ensure they haven't melted together. if the wires are fine record their position, remove them and cover the ends (seperatly) in black tape so that no metal is showing then replace the fuses and restart if they trip your compressor is fine if everything else starts then your compressor is toast. expect to spen $1500 ish for the compressor. go to aireserv.com on the right there is a repair replacement calcualtor. you'll find it is best to replace the unit. write back if it isn't your compressor and you want to tackle further issues.
Posted on May 22, 2009
    President:
  • 3,433 Answers
Chk A/C compressor clutch. Unplug and replace fuse. If it blows, The clutch is innocent. If its electrical plug is melted chk to make sure wires are seperated.Good luck
I have a 93 Cadillac Deville when I turn on the heat it blows a 10 amp fuse and the transmission stops changing gears. What is wrong?
4504204 A/c blows fuses - Document Download
thebestsolutions.top/F/cars/t4504204-c_blows_fuses
4504204 a/c blows fuses ive had feron checked replaced a/c relay fuse last about 10 ... I have a 2006 impala that is blowing the 10 amp fuse to the ac/compressor/a new will last ... 93 corolla 1.8 No start Blown ignition fuse ... i have a cadillac deville the a c blows hot air on ... air con fuses air con heating mk3 mondeo talkford.
Blower Motor Problems ' Auto Repair Help - YouTube
? 4:22
https://www.youtube.com/watch?v=2vmfxYg8LoY
Sep 27, 2009 - Uploaded by mgittelman
I have a 1996 Cadillac DeVille that the blower motor stays on unless you unplug it. ... +mgittelman hi mate ...
Cadillac Repair - Questions and Answers from October 12 ...
en.allexperts.com > Shopping > Vintage Cars
Nov 3, 2006 - 91 Fleetwood "check engine" light, 10/31/2006, Tom Joy ... Q: My 95 Deville blows air when the heat is on, but the air never warms. ... 96 Deville Interrior Lights Inoperative & 3.2 Amp Draw on Body Fuse 3. ... Q: I have the 93 cadillac deville and those codes came up right after a transmission replace.
Cadillac Seville Questions - Heating/AC fan runs when car ...
Jan 10, 2016 | 1993 Cadillac DeVille
CTSY fuse keeps blowing
ok have your replaced any bulbs? i have found putting bulbs in wrong or just being a bad light bulb can blow fuses. try replacing all bulbs with new ones. its cheap and it could be the problem
Mar 18, 2013 | 2008 Chevrolet Silverado 2500HD
Fuse blows everytime i turn on A/C in 99 oldsmobile silhouette
CHeck wires in short, ground connections or bad blower motor.
Mar 27, 2012 | 1999 Jeep Cherokee
Everytime i turn my heater on heater on works and blows fuse?
fuse blows. unplug heater blower motor turn ignition on, turn heater on, does fuse blow? if not need to replace heater blower motor
Feb 10, 2010 | 1995 GMC Jimmy
I have an spl gorilla series 1250watt amp that blows fuses
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL BLOWS THE FUSE, THEN IT WILL NEED TO BE SERVICED. IF IT BLOWS THE FUSE BEFORE TURNING IT ON, THEN YOUR PROBLEM IS IN THE POWER SUPPLY SECTION. IF IT BLOWS THE FUSE AFTER ATTEMPTING TO TURN IT ON, THEN YOUR PROBLEM IS PROBABLY IN THE OUTPUT SECTION. ALSO KEEP IN MIND THAT THE P1'S ARE REALLY NOT RATED FOR THAT MUCH POWER AND YOU MAY HAVE DAMAGED THE VOICECOILS. BEFORE REINSTALLING THE AMPLIFIER, MAKE SURE TO CHECK THE SPEAKERS FOR SHORTED VOICECOILS OR YOU WILL POSSIBLY DAMAGE THE AMPLIFIER AGAIN. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 19, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Windshield wiper fuse blows everytime I turn the ignition on
Try removing the harness connector to the motor, and see if it still blows the fuse, then you've isolated the problem.
May 17, 2009 | 1996 Dodge Ram 1500 Club Cab
JVC RX-318 keeps blowing fuses
could be several things, speaker wires touching,shorted output transistors, a shorted rectifier diode,bad filter caps in the power supply,those are the most common
Jan 06, 2009 | JVC RX-318 Receiver
Fuse burn out
thermostat section for cooling could be faulty if its electronic some short is possible on the electronic board
Apr 23, 2008 | Heating & Cooling
Goodman CKL36AR36 Air Conditioner Logo
206 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
