Question about Dell Dimension 1100 PC Desktop
Computer will not boot up and green monitor light flashes
We had a major power failure today. When power was restored I tried to restart my Dell computer. CPU does not seem to be booting up properly and monitor screen is black and the "on" light just keeps flashing on and off.
  • jed6696 May 23, 2009
    NUM LOCK, SCROLL LOCK AND CAPS LOCK are all solid green when I press them ( no flashing) but the monitor "on/off" still flashes green. Also, no DELL logo (screen is black). I think is right, time to change the motherboard. Looks like power outage fried the MB even though I was using a surge protector! What do you think?
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Do you get the flash of the NUM LOCK, SCROLL LOCK, AND CAPS LOCK, at turn on or reboot? How about a splash of Dell logo?
  • 133 Answers
You need to change *********** board.
Posted on May 22, 2009
  • Yuk-Wa Chan May 23, 2009
    That would help a bit, but not really need that.
After automatic updates and a restart, diagonstic lights A & C were yellow and D & B green, nothing comes up on screen, this happen before after an update but i got it to start after several a
If all diagnostic lights are on, then that means that it has something with the software of your computer. The update has affected some of the programs inside your computer thus it's booting up fine.
I suggest that you access safe mode and do a system restore from there. If you don't know how to access safe mode, then follow these:
1. Turn off your computer.
2. turn it on and keep tapping F8 until you see the options. You should see safe mode.
3. Use the arrow keys to select safe mode, then press enter.
4. Your computer should boot up to safe mode.
5. Access the system restore. You can find it in accessories, system tools, system restore. or you can search.
6. restore your computer to the known good date where your computer was still working fine.
7. After completing the on screen procedures, let your computer restart by itself (it may take minutes or more). It will restart and it should boot to the normal windows.
Good Luck!
I hope this helps.
Carlo
Nov 16, 2012 | Dell Dimension 2400 PC Desktop
My dell optiplex gx620 does not start and it shows no. 3 and 4 lights illuminated on its front . what could be the problem.?
One of your memory chips is bad.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Diagnostic Lights caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. To help you troubleshoot a problem, your computer has four lights labeled "1," "2," "3," and "4"on the front or back panel. The lights can be off or green. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. If the POST portion of system boot completes successfully, all four lights display solid green. If the computer malfunctions during the POST process, the pattern displayed on the LEDs may help identify where in the process the computer halted.
note.gif NOTE: The orientation of the diagnostic lights may vary depending on the system type. The diagnostic lights can appear either vertical or horizontal.
Light Pattern
Problem Description
Suggested Resolution
The computer is in a normal "off" condition, or a possible pre-BIOS failure has occurred.
The diagnostic lights are not lit after the computer successfully boots to the operating system.
Plug the computer into a working electrical outlet and press the power button.
A possible BIOS failure has occurred; the computer is in the recovery mode.
Run the BIOS Recovery utility, wait for recovery completion, and then restart the computer.
A possible processor failure has occurred.
Reinstall the processor and restart the computer.
Memory modules are detected, but a memory failure has occurred.
  • If you have one memory module installed, reinstall it and restart the computer. (see "Memory" for instructions on how to remove and install memory modules.)
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, contact Dell.
A possible graphics card failure has occurred.
  • If the computer has a graphics card, remove the card, reinstall it, and then restart the computer.
  • If the problem still exists, install a graphics card that you know works and restart the computer.
  • If the problem persists or the computer has integrated graphics, contact Dell.
A possible floppy or hard drive failure has occurred.
Reseat all power and data cables and restart the computer.
A possible USB failure has occurred.
Reinstall all USB devices, check cable connections, and then restart the computer.
No memory modules are detected.
Memory modules are detected, but a memory configuration or compatibility error exists.
An other failure has occurred.
This pattern also displays during System Setup and may not indicate a problem.
  • Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
  • Check the computer message that appears on your monitor screen.
After POST is complete, all four diagnostic lights turn green briefly before turning off to indicate normal operating condition.
None.
Jun 06, 2012 | Dell OptiPlex GX620 PC Desktop
When I restarted the computer, the monitor would not come back on. The green power light on the monitor was not lit. A few days of letting it sit there and the monitor suddenly came on again. Then, we...
Such is life when you leave both monitor and pc on all the time and have them unprotected by a surge protector and have it subjected to repeated power failures and power surges. Either the hardware fails or the system software becomes corrupted. When there is a power failure, unplug your monitor and pc, wait for power to be restored and only then plug them back in. That may not stop errors from the power failure but it will stop hardware from being fried by a power surge.
I think your best bet is to take it to a shop and have them boot the computer from a Windows 7 disk (if that is your operating system). If you video card has not been fried, that should load your drivers and operate your monitor (which you will take along also.) If it can be booted, then software corruptions introduced may be fixed and disk errors fixed. If you had an autobooting repair flash drive, it alone might fix the problem. But you would have to have a rather geeky pal around to have that. One might be made using resources at Majorgeeks.
There is a wee possibility that you could try another monitor with the system and that monitor might work and you could try entering safe mode with networking via F8 at boot. Then you might try using the sfc command or error correcting programs such as Tweaking.com's windows repair and or Glary Utilities. Sorry but the repair possibilities rather shoot off in a variety of directions. Windows 7 has a number of repair options built if you can get the system to boot.
Oct 09, 2017 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
[Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
Dell E228WFP Monitor failure
To me, that's an XP driver issue. If the screen turns on at all, then goes dark during XP boot, that's nearly a ringer for drivers.
Out of range on the Hz? Tried booting in safe mode to see if it loads with standard win drivers? That might work. Reset the monitor to default/standard settings and try safe mode is what I would do. Ramp up the resolution/refresh rate from there.
Dec 06, 2008 | Dell E228WFP LCD Monitor
Envision EN7410e monitor
hi this is jannet and am expert to solve your issues kindly call us to this numaber +1(518)348-9393
Oct 06, 2017 | Computers & Internet
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
Dell Dimension 1100 PC Desktop Logo
232 people viewed this question
Alun Cox
