Question about GE Refrigerators
Frost Free refrig/freezer doesnt get cold enough
We returned four days ago after several months absence to find that our eleven year-old Hotpoint CTX14CYZBRAD was not freezing. We had put too much in freeaer and blocked airflow. Cleared that. Checked compressor and it was hot and there was a white chalk-like residue that had run down from the top of the compressor--maybe an ounce or two. Fan was running. Now, with control set on 4, the refrigerator compartment reads 30 degrees. The freezer compartment fluctuates between 5 deg and 20 degrees. Makes ice cubes, but won't make hard ice cream. Do I have a problem or should I just wait a little longer.
    Genius:
  • 1,122 Answers
If you have 2 setting set both at the factory setting,if you don't know the factory setting set both at the halfway point and wait-mike
Posted on May 24, 2009
Freezer is slowly getting warmer - water dispenser won't dispense (occasionally) turbo cool won't work
Open freezer door and look for any frost on the back wall inside the freezer. That would indicate a defrost problem.
Disconnect power to refrig. Unload freezer, Remove shelves and back panel inside freezer. Melt frost with a hair blower. Replace defrost heater located at the bottom of the heating coils. (Note: It may look different than the original, but insturctions enclosed with replacement cover that) Might as well replace the evaporator thermister at the same time, as your problem is about 98% of the time one or the other of those parts. The thermister is a white pencil shapped item, about an inch long, located cliped to the top of the cooling coils you just defrosted.
If you don't have the parts on hand, defrosting only will get your refrig working again for several days, while you obtain the parts.
Note: non-water dispensing is the result of the cold air from the freezer not being able to continue over the frost blocked coils, so it migrates back though the return air vent in the bottom of the refrig, resulting in a frozen water line, and often freezing in the bottom bin of the refrig.
Jan 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Nine y/o GE side by side not getting cold enough
More likely a defrost heater. Look inside the freezer at the back wall. Any frost there? If so, turn off refrig., unload freezer, take back panel off inside freezer, and use a hair dryer to melt off the frost. Replace the defrost heater located at the bottom of the frosted coils. (New heater may appear different than original, but instructions are included) If you don't have the defrost heater on hand, just manually defrosting the coils and re-starting the refrig will get is cooling again for at least a week before problem will re-occur. (this give you enough time to get the replacement part)
Mar 21, 2010 | Refrigerators
Refrig will not syay cold Only 6 months old
Good day,
Not your problem. The machine carries a full one year warranty on all parts.
Call Sears for a warranty service call.
Feb 05, 2010 | Kenmore Refrigerators
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Refrig not working
what brand is this?? Model#? Is the freezer fan working?? Is the compresor running?? Is there any frost on the back panel in the freezer??
Dec 25, 2007 | Ovens
Noisy compressor
Is a Hotpoint refrig?? Ge (who makes hotpoint) is having trouble with the freezer fan howling. Check out posts on Ge SxS PSS models. Some say its the main board, i disagree.
Dec 02, 2007 | Hotpoint HSM25GFRSA
Fridge problem
i would start by changing the defrost timer . this is the most comon failure part it the frost free fridge today . good luck hope i helped
Oct 23, 2007 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Refrigerators Logo
168 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
