Question about Dryers
I have an old speed Queen coin operated dryer and I would like to remove the coin function. Can this be doneMachine detail on request.
I would like to remove the coin op function on a Speed Queen front load dryer. Will it still run?
    Problem Solver:
  • 5 Answers
You can get it to run by installing coin plugs in the slide are assembly or leave the top lock panel open and push the spring arm before each load for personal use.
Posted on May 22, 2009
I'm needing to get the lock open on my coin operated Comercial speed queen dryer , but the lock just spins. How can it get it unlocked?
Try holding the lock with a pair of channel locks while turning the key. If it opens tighten the lock from the back. If it won't open try to wedge a screwdriver under the lock face.
Sep 11, 2014 | Dryers
We have coin operated washing machines is there a sheet to show us how to change the price
http://www.pwslaundry.com/c-295851.4-commercial-speed-queen-swfx71n3000-front-load-washer-parts-for-repair-service.html
You want the one that says Programming...
Dec 31, 2012 | Speed Queen Swfx71_N3000 Commercial...
Speed Queen Front Load Coin operated # SWFT71.. The coin changer keeps getting stuck. Any ideas on how to resolve this?? How do I remove the coin changer from inside the machine??
I have not fixed any of these front loaders for a while, but the top cover should come off (usually with a key), which will give you access to the coin mechanism and timer. There you usually need a 5/16 wrench or a flat screwdriver to remove the screw at the top of the mechanism.
Dec 04, 2012 | Speed Queen SWFT71 27" Coin Operated...
Speed queen commercial dryer model sdg109wf, the coin compartment is stuck because of compartment was full, after emptying the coin slider doesn't come out so we cant use the dryer. what is the...
Oh your bringing me back to the early days of my appliance repair career when i only serviced coin operated washers and dryers. Not in the coin box but the cover on top where you would get access to the timer is a bolt that holds the coin slide to the coin box asm. remove that bolt(if i remeber from 25 years ago its a 5/16th inch hex head and brass colored) and the coin slide will come out and then gotta kinda genlty presuade it in with a hammer so the coin will drop through or pull on the handle ya would push, to free it up and remove stuck coin
Aug 20, 2011 | Dryers
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
When coin put into machine dryer started spark
Make sure someone hasnt shut off you gas supply. Check inlet gas pressure to valve. Check to see if you have voltage to the gas valve . If you have all that then the valve has bound up or burned out the opening coil . It will need to be replaced. Has this been happening to this dryer often. Do you have problems with other dryers? It sounds as though you are in a laundro-mat as the use of coins to operate.
Jul 16, 2011 | Speed Queen KGS18AWF Gas Dryer
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Coin operated speed queen gas dryer works some times and some times the heat does not work
Check the coils on the gas valve. Sounds like an intermittent one. Eric
Jun 18, 2009 | Dryers
Dryers Logo
217 people viewed this question
Top Dryers Experts
