Question about Kirby Heritage II Vacuum
Kirby Heritage II Replacing the Motor in the housing HELP!
My husband took the motor out of the vacuum to take it to the repair shop. They said I just need a new lexan fan, which he has seated now, but in the process of trying to replace the motor in the housing, a small metal piece fell out. We are not sure if it was placed inside the housing or fell from the motor assembly. It is about 4 1/2 " long and about 1/4" wide. It has a 90 degree bend on one end that is 1/2". The other end has a slight curve about 1 1/4" from the end and then has a curl on the bottom side. I know this is not much of a description. Could this be a tool that the repairman left in our box or is this some type of mounting or spacing mechanism? HELP! If you can help us out, I can send a picture of the part if that is necessary.
  • Kirby Master
  • 18,419 Answers
This mite help
Posted on Mar 23, 2017
  • 112 Answers
SOURCE: Kirby Heritage 1HD
this site may help
good luck :)
Posted on Jan 14, 2008
  • 357 Answers
SOURCE: Kirby Lexan Fan is crack and need help to replace
Check out my online instructions...
Hope they help!
Posted on Jan 16, 2008
  • 112 Answers
SOURCE: kirby heritage 2 sweeper
the above link shows you how to change the belt on the g-series kirbys but it will apply to the heritage edition as well...the only difference is the color...some of the arrows may be missing on the front belt lifter knob...but they are little differences...
hope this helps!!!
Posted on Feb 07, 2008
  • 1673 Answers
SOURCE: Kirby Heritage 2 fan replacement
Take the bag asm. and handle off. Then remove the plastic strip covering the switch, remove the screw there, remove the 3 screws on the housing, turn it over and loosen the screw near the back, the housing should come off. Then remove the screws on the back of the fan casing. You shouild be able to get to the fan, hold the fan and turn the spindle to the right to take off. If it would turn off, then you may have to lock the armature so it can't turn to move it. Then re-asemble in reverse.
Posted on Jun 21, 2008
  • 116 Answers
SOURCE: Broken Lexan fan needs to be replaced
It is similar to the G4 but without the tech drive so is easier.
Posted on Jun 29, 2009
Motor light comes on but motor does not start on Kirby Heritage II
Remember that the motor will not run unless the vacuum head or hose are properly installed. If this is not the problem, the most likely problem is that the carbon brushes in the motor are badly worn and will need replacement. A less likely problem is that the front safety switch is out of adjustment. While the light is on, remove the head and push the metal rod on the switch next to the fan inward to see if this causes the motor to run.
Jul 06, 2011 | Kirby Heritage II Vacuum
How to replace kirby heritage motor brushes
This might help you - if stuff like this doesn't make much sense to you, then have it professionally serviced for your own safety.
Feb 25, 2011 | Kirby Heritage II Vacuum
Belt for heritage 2
remove power head turn knob on front counter clockwise look in hole on back of powerhead make sure belt is on the hook install powerhead back on motor turn knob clockwise
Jun 22, 2009 | Kirby Heritage II Vacuum
Kirby Heritage II Vacuum Carbon Brush Placement
yes the carbon brushes float on the commutator and are spring loaded. the spring washer goes in the housing first then the other washer. let me know if you have any other questions
Jan 14, 2009 | Kirby Heritage II Vacuum
Replacing impeller?- how do I separate the housing
Are you removing the rear motor housing?That may expose a screw you may not have known was there.
Dec 09, 2008 | Kirby Heritage II Vacuum
Carbon Brushes wearing out quickly on Kirby Heritage II
4 possible reasons.
1 – one or both bearings are worn so armature (rotating part) wobbles as it is spinning and cause motor brushes to wear fast. Solution – change bearings too.
2 – Whoever replaced brushes – did not use some brush seating sticks to make cmutator smother and contour brushes to the shape of the comutator (not likely). Solution – appropriately install new set of brushes.
3 – Comutator is so warped that seating sticks do not help anymore – solution – new armature or turn the old armature.
4 – The fact that ONLY ONE brush was worn may mean that there is something wrong with the brush or housing. Maybe it could not move freely within the housing? I think this may be most likely cause it it may be a combination of all 4.Is it worth to fix? Hmm depends how much will it be. If this is 100+ - I’d say get newer Kirby for 300 ad enjoy the tech drive (Heritage does not have tech drive so it is much harder to vacuum with than the newer models)
Nov 05, 2008 | Kirby Heritage II Vacuum
Kirby fan on motor
I am assuming that you are trying to remove the fan. On newer models there is a cut on the shaft (rear of the motor - next to comutator) that allows to use a wrench to hold the armature, it may be very similar on older models. maybe a hole instead of the cut... You would have to access the rear of the motor though. Let me know if you cant find it - I'll take one Heritage apart here in the shop and will see.
Good Luck
Oct 05, 2008 | Kirby Heritage II Vacuum
Here are some Kirby phone numbers, they should be able to tell who does Kirby in your area. You could try calling a local repair shop to see if they can help.
May 13, 2008 | Kirby Heritage II Vacuum
Fuse for Kirby vacuum
I would take it into a local vacuum shop but DONT take it to a kirby shop because they will charge way more
Apr 13, 2008 | Kirby Heritage II Vacuum
Vacuums Logo
474 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
