Question about Ricoh Aficio CL7100 Printer
Doesn't go past warmup.
The printer (Ricoh Aficio CL7100) says it's warming up, but doesn't make any sounds like it normally does, and doesn't get past saying warming up.
  • 4 more comments
  • cgieson May 22, 2009
    There is no error message, it just says Warming Up....
    And turning it off and unplugging it doesn't help either.
    I'm having trouble understanding you. Could you try asking it again?
    Thank you.
    The fuser is not hot, took it out, the printer recognized it wasn't there, but nothing changed when put it all back. Even tried turning it off and back on, and still same problem.
  • Frank Zhang
    Frank Zhang May 11, 2010
    you may check fuser after running, is it very hot?
    take out the cartridge shake it properly reseat it. see how?
  • Frank Zhang
    just make a sense:
    1) cartridge run can not ready
    2) fuser run can not ready which heating trouble
    check it then tell me please
  • Frank Zhang
    is there any error message show on?
  • 191 Answers
You need check:
1) there are two fuses in the fuser unit, big possible one of them broken. change fuse if you can, should be fixed.
2) if check (use meter) all fuse good, so the heat lamp damaged,
you may change it also can fix it,
fuser unit maybe expansive.
hope hep you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
Posted on May 22, 2009
  • Frank Zhang
    Frank Zhang May 24, 2009
    please take a rating if the solution helped you thanks! keep in touch your comment.
  • Frank Zhang
    Frank Zhang May 30, 2009
Pages printing with a gray background
could be waste toner in printer inside the printer it may need a clean.
Apr 27, 2015 | Ricoh Aficio CL7100 Printer
Ricoh Aficio Cl7100 - Getting SC 552 error. Ideas?
Hot section problems Replace the fusing unit Its a kit make sure to put a new oil unit DO NOT USE THE OLD ONE, (sorry I yelled but new fuser failure sucks) -Carl
Jul 13, 2009 | Ricoh Aficio 450 Copier
How to get borderless printing on a CL7100
Laser printers are unable to print all the way to the edges of the paper because of the excess toner dust that will fall off into the printer unit. The only way to get true full bleed laser prints is to use a larger paper size and then cut the edges off.
Jun 17, 2009 | Ricoh Aficio CL7100 Printer
Ricoh aficio cl7100 doesn't print yellow
does the demo page print ok?
try pushing the yellow developer unit in tight.
May 06, 2009 | Ricoh Aficio CL5000 Laser Printer
Printing red stripe
Replace the magenta photoconductor.
Mar 09, 2009 | Ricoh Aficio CL7100 Printer
At start-up printer codes out a sc541 turn off then on
It's a fuser error. Fuser may need replacing, and fuser codes can only be reset by a technician, to prevent further damage
Feb 26, 2009 | Ricoh Aficio CL7100 Printer
CL7100 error message sc 440-2 Power off and On.
hello, you problem is a color(cmy) pcu motor lock, the motor is damage or exist a mechanical problem whit the pcu's
Nov 14, 2008 | Ricoh Aficio CL7100 Printer
Ricoh CL7100
THe oil unit is not entered correctly
Feb 22, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh Aficio CL7100 Printer Logo
159 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
