Question about RIM BlackBerry Pearl 8100
My blackberry pearl wont turn on
I dropped it and it landed kinda hard underneath the trackball. It flashes 3 times, pauses then flashes twice. Whats wrong with it?
    Problem Solver:
  • 18 Answers
Posted on May 26, 2009
My Blackberry pearl trackball is not doing anything but sometimes a hard reboot helps. Will reloading the software help?
Chances are it's just dirty from use. If you can carefully remove it and clean the contacts with some rubbing alcohol and let it dry, then replace it, it should work just fine.
90% of trackball problems is simple gunk build up
Sep 12, 2011 | RIM BlackBerry Pearl 8100
BlackBerry Pearl 8100: blackberry pearl roller ball sticks...
it is because of the dust accumulate din between the trackball and the wheels...so remove the trackball and clean it....u can be abe to do it by your own... for assistance watch this video,to solve this problem http://www.youtube.com/results?search_query=blackberry+pearl+8100+trackball+repair&aq=f
May 05, 2010 | RIM BlackBerry Pearl 8100
8220 , trackball wont go down
Trackball doesn't work if you have not selected the sensitivity.
To select the sensitivity, kindly follow the steps:
1. Select menu.
2. Select option.
3. Select screen/key board.
4. Scroll down to find horizontal and verticle
5. Select horizontal-100 and verticle-100.
Oct 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
My trackball on bb 9000 won't move down
good luck.
if you can get the part -- its a trackball assembly btw not just the ball itself
you press down on the silver ring around the ball and turn, the cover will fall out. use a small probe and lift the assembly out.
many times there's fuzz in there -- check it out before you buy a new assembly
Jul 23, 2009 | RIM BlackBerry Pearl 8100
Trackball want scroll down
Please change the sensitivity, to change the sensitivity follow the below steps
  1. select option in the main menu
  2. select Screen Keyboard
  3. set the horizontal/vertical sensitivity as 100%
May 16, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Dropped phone won't work
You've ruined your blackberry to say the least. I used to have the blackberry pearl, your going to have to take it to a technician because you probably damaged some internal hardware. Your best bet is to take it to a technician to have it repaired, if they can even repair it, or buy a used blackberry from your cell phone company. Kinda sucks, but that is how they make there money- and get a touch case if you choose to get a new one. Swissgear is very very durable! Sorry your having a problem! Wish you the best of luck.
Mar 19, 2009 | RIM BlackBerry Pearl 8100
Curve 8330 has a trackball issue
Good evening!
Removing (or replacing) the trackball on the Blackberry phone is very easy.
Shut off your blackberry phone (I would take out the battery).
Quickly examine the trackball itself on your phone. Use something with a small tip, like a screwdriver (NOT A KNIFE! Could damage the mechanism), and slide it underneath the silver ring around the ball. Gently lift up, might also want to try lifting both sides to help lift it off.
Once off, set aside the silver ring. You should now see the trackball mechanism, to remove it, simply flip the phone over and it should just fall out (can also tap it a few times which helps). The mechanism is simply held in magnetically.
You should now be able to see where the trackball was. You can now take a cotton swab with a small amount of rubbing alcohol and clean around in that area. If you examine, you will see small rollers around the trackball, you can also clean these.
This is the best way to clean the trackball. If all else fails you can replace the trackball. You can order one off amazon, they are very cheap, ranging from $2-10.
To put in the trackball, simply reverse the steps. The trackball device only goes in 2 ways, if it simply doesnt fit, turn it. It requires minimal force to put it back in. To put the silver ring back in, just match up the 3 little clips and gently push it back in.
Put the battery back in and give it a test.
Hope this helps!
Feb 26, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry trackball wont work
Buy an iPhone, they don't have hokey trackballs.
Sep 29, 2008 | RIM BlackBerry Pearl 8100
Blackberry rollerball
Hi guys I have the solution. I think all your trackballs are stuck. If you cant move it, take the silver ring off with a knife, take off the trackball and put rubbing alcohol on it wth a Q - tip until it works. Can some1 help me? My problem is titled My blackberry pearl wont load up.
May 16, 2008 | RIM BlackBerry Pearl 8100
Blackberry pearl
satan phone? get a waranty replacement
Apr 07, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
229 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
