Heat Pump no longer produces cold air. Blows good but not cold.
I have an Amanda Heat Pump. Model number is PTC153A35AD. It does not produce cold air, just barely cool. I pulled the cover off and the little indicator light blinks once which I believe means that the board is okay? Gordon
  • 21 Answers
It sounds like you have a refrigerant leak. If both coils are clean and air fiter is clean nad you can hear compressor running, most likely refrigerant leak. If this unit has heat strips verify they are not running during cool mode.
Posted on May 22, 2009
  • 116 Answers
Make sure the coils are clean run unit a bout 20 min take cover off and feel the lines on the compressor the big one should be cold and small hot feel top of compressor to make sure running
if big line not cold most likley freeon has leaked out if compressor not running low psi may have unit out look at the compacitor if swelled up bad hope this helps
My 2009 i30 diesel heater only blows cold air changed coolant leave it running for 1 hour and still cold air
One thought. Diesel engines do not produce vacuum. Since the heat and AC controls are vacuum actuated, and you have no heat, the main flap over the heater core is not being opened to allow the heat to come into the cab. Meaning it's getting no vacuum. Check that all vacuum lines are connected from the vacuum pump, then check that the vacuum pump is working. If the vacuum pump is not pulling vacuum, there's your problem. Makes sense, huh?
Nov 26, 2017 | Hyundai i30 Cars & Trucks
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
A/c blows warm air when idle, when vehicle accelerated blows cold air. what gives?
when a vehicle stops but is still running it produces a lot of heat,since you still feel some cold air from your ac ,it is working,however maybe not up to par or its just not as much as you would like.The reason it feels cooler when you are driving is the ability to get rid of the heat from the motor because the airflow pulls away the heat from the engine and helps the cooling system.
Jun 06, 2012 | 2006 GMC Envoy Xl
The heatpump blows out air ok but no heat?
You are probably going to have to call a Hi Vac repair as your freon is probably too low to operate your Heat Pump properly. The only difference between the Air condition side and the heat side is a reversing valve that takes the heat produced by the Air Conditioning (cold) side and sends it into your house and exhaust the cold air out side. If the pump cannot produce heat from the expansion and compression of the freon, then no heat. You may also want to check that the pump is running as it is protected by two large BUSS fuses on the AC power to the heat pump and if any one or both of those fuses are blown, then no power to the Heat Pump. There should be an 8 inch square box mounted on a wall next to the heat pump that supplies 220V to the pump.
May 17, 2011 | Heating & Cooling
Fujitsu heatpump 13 years old is not heating room as it used to.filters are clean.i have gauges and would like to know what pressures are good and what pressures indicate low refrigerant or worn...
The refrigerant and compressor are related in cooling the room.As for heating problem the thermostat needs to be checked.
if you're used to a certain temperature of air and your heat pump is producing much cooler air, take the following steps. (Note that a heat pump may go into a defrost mode to prevent icing. When this happens, it can temporarily output cold air. Also be aware that the heat pump will have to work harder to produce heat.)
1) First be sure the thermostat is set properly. Try raising the set temperature 5 degrees F. and waiting a few minutes.
2) Be sure the room-heating registers are open.
3) Check the heat pump filter. If it's dirty, change it.
4) Be sure the auxiliary heating elements are working .
5) Clean the coils of the outdoor condensing unit.
If still the same problem then thermostat needs to be checked and replaced.
Thanks.
Jun 15, 2010 | Heating & Cooling
MY HEATER BLOWS HOT AIR THEN BLOWS COLD THEN HOT THEN COLD,ICHANGED THE MOTHER BOARD, RELAY SWITCH, AND THERMOSTAT, IT IS RUN FROM A HEAT PUMP WITCH I HAD CHECKED AND IT WORKS FINE
I have a lux electric thermostat my furnace will blow out heat for about one hour to maybe three then it will start blowing cooler air,I then cut it off for thirty seconds or longer once I do that it will start blowing out heat again then it will repeat it self again what could be the problem.
Jan 07, 2010 | Heating & Cooling
No rear heat
The rear vent system has a separate heater core/blower system. heater core could be plugged up or the coolant lines going to rear heater core are plugged. could also be low coolant/faulty water pump not producing enough pressure, or air in the cooling system which will need to be bled if so.
Feb 22, 2009 | 2001 Dodge Durango
2006 ford f-250 diesel with no heat
it takes quite a while for a diesel to warm up by just idling in order to produce any heat.you have to put them under a load (drive it), before you will get any noticeable heat.if you have a block heater, plug it in 4-5 hours before you plan on driving it and that will definitely help produce interior heat quicker.
Feb 22, 2009 | 2006 Ford F-250 Super Duty
A/C button produces heat and heat button produces cold air
sounds like the blend door in the HVAC unit is malfunctioning. there is a servo motor that switches a door from the cold side to the heater core side for hot air. sounds like thats what it is. hope this is helpfull
Jan 16, 2009 | 1999 GMC Jimmy
Heating & Cooling Logo
326 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
