Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
My troy bilt tb425 cs won't start, gas coming out at air cleaner
I took the air cleaner cover off to clean and tried to start it with cover off and gas squirts out of the cleaner when i pull the cord
    Problem Solver:
  • 9 Answers
You need to clean the carb. First remove the air filter cover and filter. Then remove the 4 screws that hold on the primer bulb. Be very careful as there is a spring in the carb. that will "jump out"! There are a few gaskets and aluminum pieces. pull them off in layers and be cautious as they need to be put back on in the same order. Clean all of the visable parts with brake cleaner DO NOT USE CARB AND CHOKE CLEANER! if you do the gaskets will swell and will not be reusable. On the last plate there is a gold colored jet remove it with a small scredriver. it is a semi cylindrical brass tube. There is a very small hole in the center of this. It must be cleaned as it is clogged with trash. after cleaning all of the parts with brake cleaner reassemble in the same fashion as disassembled. prime the fuel bulb and start it up... That should take care of all the problems listed above.!!!
Posted on Jun 13, 2009
Troy-bilt 34322 343220110815 mower will not start
Dump out old gas. Fill with fresh gas. Always use Stabile in gas. Clean or replace park plug and air filter. Check oil level. All mowers have a low oil start cutoff. 30w oil. If any grey in oil moisture contaminated, dump out old oil and refill. Check fuel line for cracks or leaking. Check primer bulb for cracks, replace if required. Clean outside of carb with carb cleaner to ensure easy choke operation. Remove carb bowl from carb, ensure float hangs down freely. float down fuel flow, float up fuel flow stops. Check bowl screw for hole thru bolt, if so clean out hole.
Sep 11, 2012 | Troy Garden
Troy bilt trimmer idle problem position 2 shut off
try fresh fuel fuel is only good for 30 days in small engines if not the carb needs a good cleaning
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
My Troy Bilt TB20CS won't start. Can you give me any do it yourself advice, such as rebuilding the carb? and where to find discount parts? The machine is only a couple years old and with very few hours of...
I have the same tbs20cs it starts ok but it will die when I shift to run. I looked at the fuel lines and they fell apart in my hands perhaps due to the ethanol in the gas. I cleaned the carb. with a good quality cleaner but no diff. please help solve why it dies.
Oct 14, 2010 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
My troy built starts but will not speed up enough to use even after it warms up. It is 2 years old but only has 3-4 hours of use on it . Can you help me?
Is it 2 cycle or 4 cycle? Meaning, does it take plain gas, or mixed gas?
Clean the plug, clean the carb with either choke cleaner (4 cycle) or wd-40 (2 cycle) by spraying it into the choke hole after you take off the air filter.
You may also want to spray some of the choke cleaner or wd-40 into the gas tank with the gas to help clean out the whole fuel system.
Only use choke cleaner for 4-cycle regular gas units. For mixed gas, use wd-40 in place of choke cleaner.
Try to start it and then go back and forth from half choke to full choke until it starts picking up.
Jul 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt mower ran fine then died and now it wont start back. It has fire and a new spark plug. It gets fuel past the filter. It starts if i put a small amount of gas into the intake. Whats wrong? My...
Remove the air filter and set aside.
Take a can of carburetor cleaner and spray the inside of the carburetor.
Let it set for a moment and then try starting the engine. It should run a few seconds. Repeat. When it starts squirt a small shot of cleaner in the carburetor to keep it running. That should remove the varnish the gas leaves as it evaporates over the winter.
If it still won't keep running then there is trash in the float bowl plugging the needle valve seat and the jets.
1) Turn off the gas or remove the gas line and plug it with a small screw or stick to keep it from leaking out of the gas tank.
2) Look on the bottom of the bowl for a nut .
3) Remove the nut and drop the float bowl.
4) Carefully remove the pin holding the float and needle valve assembly.
5) Take the carburetor cleaner with the straw it comes with and spray every hole in the carburetor to clean the jets . (up through the needle valve seat, down top of the carburetor , see a hole, spray it with the cleaner.)
6) Clean the float bowl.
7) Reassemble and make sure the gas isn't leaking and try to start it again.
Jun 06, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
Will cleaning my Troy-Bilt TB25CS carburetor heal it?
Since the air from the air filter does not go through the carb, the carb cleaner will not either. If you remove the carb and spry all of it that you can get to, you may get the plug. If you were to open the carb and go through it and clean it you would need to get new gaskets and maybe that will do the job. You may be able to adjust the carb. There is a "hi" and "low" setting. Try adjusting the "hi"...Lee
Aug 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
My Troy Bilt Self Prop. Z-start won't keep running. I clean All, replace Filter and Plug, have clean gas and lubed all. It Starts for 2 seconds and then cuts off. What do you think it could be? Thanks....
I had the same problem, Tilt the lawnmower on it's side air filter facing up and remove air filter cover and air filter then remove the fuel bowl underneath the carb; then clean the fuel bowl with some gas and a clean rag. For the next step be sure to aim blower tip at target then look away before pressing trigger, this will prevent gasoline form getting into your eyes.Take an air compressor and carefully clean out the carb where the flap is and the tube where the fuel float that would rest inside fuel bowl is. Leave on side install everything back except for air filter and cover. Then pour a little gas in the carb to prime it, lay the lawnmower back on all 4 wheels and try to start.
Aug 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
675 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
