I can't get exchange to smtp out. godaddy was the email host but they weren't very helpful and change MX to point to my server. Now it's worse... can't get incoming or outgoing.
  • 1 more comment
  • servercrash May 11, 2010
    gotohttp://www.mxtoolbox.com and run all of the diagnostics offered there, sounds like a DNS problem, possibly a reverse DNS problem, what is your domian? i can troubleshoot it for you
    kris
  • ultimitloozr May 11, 2010
    SMTP out issue could be a DNS problem. Check that your resolver is working properly on the Exchange server by trying to ping any machine on the internet. If you have a firewall, it could also be blocking your Exchange server from sending traffic out to the internet.
    Also, when MX records are changed (or any DNS records for that matter), it takes some time to propogate through the system. It can affect mail delivery for a couple of days. It is generally better to add records and verify their proper operation before deleting old ones.
    If these are not the problem, I'll need to know your domain to further troubleshoot the issue.
  • Michael Rodriques May 11, 2010
    What version of exchange?
  • 31 Answers
1. The mx record has to be changed to an adress, which can be reached from the internet. It has to be an public IP Adress or you have to use dyndns.org or something like that. If the Server is not reachable directly in the Internet, you have to set your Internetrouter to forward smtp to your server in your network.
2. There are cases, when you need to configure a Smart Host for your e-mail server. A typical example is the situation, when your ISP blocks outbound connections on TCP port 25. Another, very common case is when you are using an IP address which belongs to a range of Dynamic IP addresses. It is a common practice to drop smtp connections or discard e-mail messages sent from a dynamic IP address.
a. Open your Exchange System Management Console - Administrative Groups - "Groupname" - Server - "Servername" - protocols - smtp.
b. Click right to"virtual standard server for smtp" and choose properties.
c. Change to tab delivery.
d. Then choose the button advanced.
Here you can set the full qualified domain name and you can set a smarthost entry. May be this helps
take also a look at http://codebetter.com/blogs/john.papa/archive/2007/04/02/Problems-Sending-Mail-on-Dedicated-Server-with-GoDaddy.aspx
Posted on May 28, 2009
Smtp port
Networks assign port numbers to different types of incoming and outgoing traffic.
One example of this is the port assigned to SMTP (Simple Mail Transfer Protocol), which is used to package and transfer electronic mail, or email.
In most cases, SMTP is assigned to port 25 in the network's Exchange server.
If you want to find out which port your network uses to route SMTP traffic, you can check it by logging in to the Exchange server
Log in to the Exchange System Manager in your mail server.
Click "Servername."
Click "Protocols."
Click "SMTP."
Find the icon labeled "Default SMTP Virtual Server" and right-click on the icon.
Select "Properties."
Select the "General" tab and click the button marked "Advanced."
Read the value listed in the entry for Transmission Control Protocol (TCP).
This value is the SMTP port used by your network.
How to change SMTP port 25 to another port in Microsoft Exchange Server
http://support.microsoft.com/kb/274842
Apr 23, 2013 | Computers & Internet
Copystar CS-C3225 color copier scanner. The Scan to Email quit working. It says Unable to find SMTP server. A Windows box and an iMac print to this. We updated the driver on the iMac for this and n
Updating a driver would not affect the mail server settings. could be a firewall issue but i doubt it. is the smtp server on your lan or are you using a hosted mail solution? the only things that matter there are the ip address of the smtp server, authentication, ssl (or not), port numbers, default from address, dns settings, and message size. the mail function is totally independent from you computers operation unless an on site server or workstation is hosting the smtp server.
Jan 10, 2013 | Copystar Cs-C3225
I have tried to get my yahoo account connected to work with outlook to no avail
Do you pay for your yahoo mail? If you use the free version, you can't do it.
If you have Yahoo Mail Plus (19.95/yr) then go to the mail options.
  1. Go to Tools and Account Settings - below the E-mail tab click New
  2. Choose E-mail Service. Click on the Microsoft Exchange, POP3, IMAP, or HTTP radio button
  3. Click the manually configure server settings or additional server types check box. This will automatically enter in all of the required fields
  4. Click next
  5. Click on the Internet E-mail bubble. Click next
  6. Enter the following information:
    Your Name: Display Name you want to use, for example, Jo Bloggs
    Email address: Full email address, for example, jo.bloggs@yahoo.com
    Incoming Server: Contact your ISP or Hosting Company for this setting. (See note below if your mail provider is Yahoo!)
    Outgoing Mail server: Contact your ISP or Hosting Company for this setting. (See note below if your mail provider is Yahoo!)
    User name: The first portion of your email address, for example, jo.bloggs@domain.com
    Password: Your email account password
Note: If your mail provider is either yahoo.com, rocketmail.com, or ymail.com then the incoming and outgoing settings are as follows:
  • Incoming Mail Server pop.mail.yahoo.com
  • Outgoing Mail Server smtp.mail.yahoo.com
If your mail server requires SMTP Authentication, follow these steps. If you are not sure if your mail server requires SMTP Authentication, please contact your hosting company or ISP:
  1. Click on More Settings
  2. Navigate to the Outgoing Server tab
  3. Check My Outgoing Server requires SMTP Authentication
  4. Click OK
  5. Click on Next
  6. Click on Finish
Apr 24, 2011 | Computers & Internet
Trying to set up outlook on yahoo at&t
One issue you may have is outgoing mail. Some ISPs insist that all outgoing mail goes through there servers, to protect against imposed spam fines... Sometimes you have to send through another port, gmail does that....Then ISPs usually let that go...Much better setting for mobile user...
Below is what you need to do:
http://help.yahoo.com/l/us/yahoo/mail/classic/mailplus/pop/pop-36.html
Here's how:
  4. Click next
  4. Click OK
  5. Click on Next
  6. Click on Finish
Feb 14, 2011 | Microsoft Office Professional 2007 Full...
I get "Send Error (SMTP)"
It took me a while to figure this out. Your 3220 must be connected to ethernet (I havent tried it with the 3220 connected directly to the computer). Also, this works with a free email with domain Godaddy account, so YMMV.
1. Open your web browser and navigate to the 3220's CentreWare IS. 2. Click on "Protocol/SMTP Server" 3. Check "Host Name" 4. Type smtpout.secureserver.net/80 for server/port 5. Check "SMTP requires authentication" 6. Enter your username/pw 7. Click "Save Changes"
If you are asked for a username/pw to save the settings, the 3220's default are admin/1111.
Now click on "E-mail/E-mail Setup" on the navigation. Make sure your default [From:] address is your sender email address (they must match). Click "Save Changes"
As a final recommendation, I strongly suggest that you create your address book (E-mal/Local Address Book on the navigation) to make it easier to send by email, otherwise you will have to manually enter email addresses using the 3220's keypad (very slow!). Create groups for sending scans to several emails without having to select each individual email from the 3220's panel (also slow!).
Hope this helps.
Dec 31, 2010 | Xerox WorkCentre 3220 All-In-One Laser...
Unable to access mailserver from out side my office
I have no idea what firewall you are using. Your posting is lacking crucial detail and that makes this almost impossible to answer you. However, I use a Cisco 5520 in a Data Center and i Host my own Exchange server. This is what you have to do to allow inbound and outbound SMTP traffic in that type of environment.
name (Internal IP here) Exchange description Internal mail server
access-list Inside_access_in remark Allow internal Exchange Server to send SMTP email outbound.
access-list Inside_access_in extended permit tcp host (Internal IP Here) any eq smtp
access-list outside_access_in remark Allow external entities to send SMTP email to Exchange Server
access-list outside_access_in extended permit tcp any host (Public IP Here) eq smtp
Hope this helps you.
Brian
Jun 29, 2010 | SonicWALL NSA 3500 (01-SSC-7016) Firewall
Pop email settings with godaddy domain
I FINALLY GOT THE ANSWER! I ALSO HAVE A GODADDY EMAIL ADDRESS AND USE A HTC TOUCH PHONE FROM SPRINT. I've entered the following settings and my email now works like a charm! This is for a POP3 email address, not an IMAP email address.
You cannot send the email unless you have a sprint email address. Email must go through the Sprint server in order to be sent (incoming mail does not).
Call Sprint Tier II (877.345.7895) and ask them to set you up with a User Name and Password for the outgoing mail server. All the rest of the settings are as follows:
EMAIL SET UP Email Address: You@YourGoDaddyDomain.com Your Password: the password you use to access your go daddy account Check SAVE PASSWORD Click NEXT UNCLICK TRY TO GET EMAIL SETTINGS AUTOMATICALLY FROM THE INTERNET. Click NEXT. Your Email Provider: Internet Email Click Next Your Name: Dales Wife Account Display Name: 'GoDaddy Email" or whatever you'd like to call it so you can identify this account (you can have several email accounts sent to your phone). Click NEXT Incoming Mail Server: pop.secureserver.net Account Type: POP3 Click NEXT User Name: Again enter You@YourGoDaddyDomain.com Password: Enter your password again Check SAVE PASSWORD Outgoing (SMTP) Mail Server: smtp.sprintpcs.com CHECK Outgoing server requires authentication UNCHECK Use the same user name and password for sending email Advanced Server Settings: DO NOT Check: Require SSL for Incoming e-mail DO NOT Check: Require SSL for Outgoing e-mail Click DONE to return to previous screen Click NEXT Outgoing Server Login: TheNameGivenToYou@sprintpcs.com Password: When you call Sprint Tier II they will ask you what password you'd like. Check Save Password. Automatic Send/Receive: I use every 5 minutes and it doesn't seem to run my battery down. Click FINISH. This has been driving me crazy for two months now so I really hope this information helps somebody else out. Best of luck! NOW, if anyone knows how to remove those annoying envelopes when I access my mail - I could use the help. There are three envelopes there (one for GoDaddy mail, one for Outlook and one for Picture Mail.) I do not use Outlook or Picture Mail and would love it if I could remove those.
Dec 20, 2008 | HTC Touch Pro Smartphone
Error message #80070002 treo 750
Ok, email can be setup using a bunch of different protocols. The difference is how directly you phones data and the data on the server interact. POP and IMAP are methods for receiving email from the server, to send they use a protocol called SMTP. With POP3, email is all downloaded to your phone and saved there, with IMAP you only download the headers (...a header is like the back cover of a book). An Exchange server can do SMTP with either POP or IMAP, but when it says configure for Exchange - it means actually connecting to the mail server and integrating contacts, calendar items, email, like the Outlook client on your Windows machine. This is obviously much more server intensive and requires special permissions to do.
POP and IMAP will require the following information to work. Your login name, your password, your server, and whether the connection is secure. To find these out you can go to your coporate webmail. The user name is what you put in the user login spot, as is the password, the server will usually be either mail followed by a dot and the second half of your email address, or the web URL for the mail server...if the web access page address starts "https" then the connection is most likely secure.
This link may help further...
Jul 22, 2008 | Palm Treo 750 Smartphone
Can not send e-mail
Have you made any changes to your pop3 server?. Look at your option in outlook it is under accounts. And check to make sure the server setup is right for your email. Most times the mail server and pop server are the same. Like
incoming pop3 (server whatever.com)
outgoing smtp( server whatever.com)
Mar 02, 2008 | Computers & Internet
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
