Question about Craftsman Garden
Does not continue to run when choke is not in use.
Craftsman Garden Tractor, Model# 917-275970. Problem: runs only when choke is out. I have checked fuel filter, cleaned carburator, checked fuel pump. Can someone help me?
    Problem Solver:
  • 11 Answers
Is the high flow ports on the carb clean? does the engine have good compression?
Posted on May 23, 2009
Tractor runs crappy and then dies once i put it in mowing mode
does it run a little better with the choke on part of the way? did you leave gas in it from last season?gas is only good for about 30 days in a small engine
Apr 28, 2012 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I HAVE A 6000 CRAFTMAN WITH 26 V KOLER STARTS RUNS WITH THE CHOKE OUT . AS SO AS I PUSH THE CHOKE IN IT STOP RUNNING
Its a fuel problem. Remove fuel line from carb. Remove fuel cap, vent in it is common problem. A small hole in cap.
Aug 31, 2011 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Tractor only runs with choke on , stalls when you take choke off
The choke cable needs adjusting. There is a strap holding the sleeve on the carb. loosen it and adjust the choke position, then tighten it up again.
Thats it
Mike
Aug 30, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
My craftsman 18 HP tractor model 917.274400 will not run
Sounds like something is clogged. It may need a new air filter or the carburetor may need cleaning out. Also I would check your fuel, if it is over 30 days old I would replace it. It may be losing compression and either need a new head gasket or the head bolts tightened when it is hot.
Good day.
Oct 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have to run my craftsman 19.5hp lawn tractor (model # 917.270824)with the choke partly open in order for it to run smoothly. What adjustment needs to be done to correct this?
Hi..my name is Keith..and you need to turn the main jet needle out a little bit..its located on the bottom of the float bowl of your carburator..i hope this has helped..if not..please write me back
Jul 08, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tractor won't stay running
You will have to pull the carburetor off and rebuild it. This means cleanig and adjusting. This should help your cause a bit. donnyb60
Mar 21, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
198 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
