Cant get on the internet
Just reformated my girlfriends Dimension 4600c computer, and i installed nearly all the drivers excluding the SM bus controller and Universal Serial Bus, yet i cant get on the internet, im using a linksys adaptor to get on the internet, it says im connected but still not getting internet.
  • jcoady
    jcoady May 11, 2010
    What OS are you running?
    Are you getting an IP address?
    To check, either go to a command prompt and type "ipconfig", or
    (GUI method)
    Go to "Network Connections", right click on the "Local Area Connection", choose Status, and click on the \Support\ tab.
    NOTE: An IP address beginning with 169. is an indicator that no IP address has been assigned.
    If the answer is 'No':
    Ensure that the adapter is configured for DHCP ("Local Area Connections", Properties, TCP/IP).
    If you are using a router or a cable/DSL modem recycle power to them and restart your computer to see if that fixes it.
    Try a different computer on the same connection to see if the problem still exists.
    Try a different Ethernet cable.
    But, if you do have a valid IP address:
    Reset any home router/firewall device by recycling power (same as above)
    Contact your ISP and ask them if they can 'see' your cable/dsl router remotely.
    Try connecting directly to the cable/dsl modem.
    NOTE: You'll need to recycle power to the router & modem each time you change devices connecting to them. The modem especially will tend to 'lock' on the MAC address of the device connected. The only way to quickly change devices and reset this is to recycle power to them.
    I hope this helps.
  • Dick
    Dick May 11, 2010
    "linksys adaptor" + "installed NEARLY all the drivers excluding... Universal Serial Bus"
    See a potential problem there? Where is your linksys adapter plugged in if you don't have USB drivers installed?
    Problem Solver:
  • 5 Answers
Please cheeck that the modem and router have been configerated and has the correct ISP information.
Posted on May 23, 2009
I lost the wire loop to hold down the heat chip what else can I use to replace the wire loop
http://support.dell.com/support/edocs/systems/dim4600c/sm/index.htm
I would use a piece of thin coat hanger, and bend the configuration I need.
http://support.dell.com/support/edocs/systems/dim4600c/sm/sffprcsr.htm
Make the configuration very close to the original green Securing Clip.
OR,
Go to Dell Spare Parts, and see if you can buy the Securing Clip.
Have the Serial Number written down. (S/N)
I didn't see it by searching with Dimension 4600C.
Not the best solution I'll admit. The only other thing is to search the internet for the clip, or buy another motherboard.
Regards,
joecoolvette
Sep 17, 2011 | Dell Dimension 4600C PC Desktop
I'm getting this error message "chipset heatsink not detected system halted" What does that mean, and is there a fix for it?
it means that the chipset heatsink on the motherboard has come loose. There is a sensing circuit that is closed by the spring clip that holds the heat sink in place. One of the loops on it has broken, causing the error.
Resolution is motherboard replacement
http://shop.ebay.com/i.html?_from=R40&_trksid=m570.l1313&_nkw=dimension+4600c+motherboard&_sacat=See-All-Categories
installation information:
http://support.dell.com/support/edocs/systems/dim4600c/sm/parts.htm#1102134
Aug 08, 2011 | Dell Dimension 4600C PC Desktop
Hello I reinstalled windows xp home on my Dell 4600c desktop and no longer have ethernet controller, multimedia audio controller, SM Bus controller or Video Controller VGA compatible. Can anyone help me...
You can download the drivers here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
Considering one of the drivers you need is the ethernet controller, you will not have access to the internet. After you download the neccessary drivers from a different computer, you can burn them to cd or put them on a flash drive to transfer them to the dell.
Nov 08, 2010 | Dell Dimension 4600 PC Desktop
SM Buster Controller driver for dimension 5150
Access the manufacturer's web-site: http://support.dell.com
and enter '5150' and do a search.
Select your Operating System.
Select the appropriate device-driver(s) for your 'SM Bus' device.
Download.
Install.
Oct 21, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I cant install sm bus controller
The SM Bus Controller is usually a driver for the chipset. You should be able to find it by going to Toshiba's website, entering your info when prompted for it, choosing the operating system that is on your computer, and then downloading and installing the Chipset Driver.
May 14, 2010 | Toshiba Satellite Pro L300 Notebook
Reformat done and now there is no internet connection. I need the ethernet controller and the sm bus controller. Everywhere I go...they want to download that program that tells me what drivers I need and...
No, you don't need to download the drivers you have to looked for the motherboard installer of your PC, then install the chipset of your motherboard in order for you to use the internet connection.
Jan 21, 2010 | Dell Dimension 4550 PC Desktop
Drivers for dell dimensions 2350
i get most of my drivers from driverguide.com it is free
Jun 18, 2009 | Dell Dimension 2350 PC Desktop
Reloading software, Hard drive replacment
i hope u re install your operating system,
after the re installation u did not install the drivers that is the reson, best way u buy an ethernet card and try to get net connection and down load the drivers from dell.com ,then remove the card ,thats it.
Jan 15, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
211 people viewed this question
David Payne
David Payne
