Question about HP Officejet 7210 All-In-One InkJet Printer
Printing blue I've installed new black and color cartridges and aligned and cleaned heads. It will print some black, but most of the type prints blue, no other colors.
  • 133 Answers
Printer defective.
need a new machine.
Posted on May 22, 2009
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
I have two cartridges in my 5610 a #22 color and a #27 black. I received a low ink message, but didnt know which one was low. I noticed that the most recent Word document looked fuzzy so I replaced the...
Hi
You can bypass the alignment on 5610 by pressing ok to start alignment
and then cancel
after that check by printing a document if your cartridges work fine if not
you can refill them with this easy and cheaper method
Jan 19, 2011 | HP Officejet 5610 All-In-One InkJet...
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
I replaced the printhead back in january, but did not use the printer. it has been packed up until now. i replaced the ink cartridges and put in the new print head. but cannot see the text or anything...
It is not clear which print head you changed. some time the printer, if it has 2 different print head, for black and color, you may have to try changing the black print head.
But before doing all that , make sure that the ink cartridges are full.
print an alignment page and then try to make a standalone copy.
clean the ink cartridge with lint free cloth. Also check the preview of the text before printing.
You may also try to do a complete uninstall and then reinstall of the printer driver.
Aug 12, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
New black cartridge installed in MP780 Prints
This simply means that black ink is installed but not CHARGED properly. What you see in a color printing has actually no black color in it but a combination of the hues of blue and yellow and magenta; though it appears black or dark.
Now, use your printer's maintenance utility to do Head Cleaning. To do this, click Start => Settings => open your Printer and Faxes, then right click on your printer's name. Then click on Printing Preferences. Now in the window that opens, click the Maintenance tab and do Head Cleaning. (In some printers, maintenance is called Toolbox)
Dec 20, 2009 | Office Equipment & Supplies
Black ink not printing or very light or split. Have installed new ink cartridges. Getting some color and headings or seals. But mostly Blank!
HI
Usually when you install new cartridges,the printer print an alignment sheet.
in case if the printer isn't printing the colors okay,
you can try cleaning the cartridges by going to the printer drivers,
goto the control panel--->printers and faxes--->rt click the printer icon and goto properties,under properties there should be an option for either maintenance or service this device button,when you click it ,it gives an option for aligning the cartridges,
you can also goto the printing preferences and it allows you to adjust the color
there is an option to clean ink cartridges
Jul 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Phote prints out faded and in black and pink only
There are a number of single issues that can cause your problem in this case. The most common are listed below:
1.) Color cartridge expended.
2.) Print Paper selection incorrect.
From your statement above. I would suggest it is both item 1 and 2. Since, we are doing this assistance via chat mail, I can't come to your aid and witness myself what the results are and what your settings are for the paper type.
When you end up with a red hue over all over the print area the cause it usually a bad print head and selecting the wrong paper type.
To answer you question then, Yes, replace your color cartridge. But, first, try this method below to clean your color cartridge bubble jets.
When you go to print a job, always go into print setup or printer properties and choose the paper type as closely as you can to match the paper you are using.
The print head manual cleaning is listed below, it is from Lexmark. Below that is a process to clean blurry and bad print results. Although this is not specifically the case in your problem. The process to achieve resolution will also correct any problem your machine may be having. Remember, I do believe you need a new color cartridge. You will know with certainty however when you clean the cartridge head. If you do not see, cyan, magenta and yellow lines upon cleaning, at all, ever, then those inks are depleted. Replace your ink cartridge and then do these steps below the head cleaning.
Also, when ever you change a black or color cartridge you will want to run a print head alignment test and adjustment. There is enough of a difference in cartridges that this is quite necessary.
Please do not hesitate to give me as much feedback as possible on any issues and results you discover. You can use the comment text area below to respond to these instructions and give me the results of your tests and procedures.
Regards, Worldvet
Cleaning procedure
  1. Remove the print cartridges.
  2. Moisten a clean, lint-free cloth with water.
  3. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown below.
  4. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown.
  5. With another clean section of the cloth, repeat steps 2 through 4 above.
  6. Allow the nozzles and contacts to dry completely.
  7. Reinsert the print cartridges.
  8. Print the document again.
  9. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
To Resolve Print Quality Issues (below is for blurry lines, it will resolve many other issues too, so proceed after replacing your color ink cartridge if upon cleaning you see no ink coming out and the cartridge feels very light and makes little to no sound when you shake the cartridge.)
Overview This article outlines various techniques for resolving a blurry print issue. Cleaning the print cartridge nozzles is necessary when:
  • Characters are not printing completely.
  • White dashes appear in graphics or printed text.
  • Print is smudged or too dark.
  • Vertical, straight lines are not smooth.
  • Colors on print jobs are faded, or they differ from the colors on the screen.
Clean the Print Cartridge Nozzles using the Computer
    1. Load plain paper.
    2. Open the Lexmark Solution Center (go to Start, Programs, Lexmark XXXX Series, Lexmark Solution Center).
    3. From the Maintenance tab, click Clean to fix horizontal streaks.
    4. Click Print. A nozzle page prints, forcing ink through to clean the clogged nozzles.
    5. Print the document again to verify that print quality has improved.
    6. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
Clean and Wick the Cartridge
  1. Try cleaning and wicking the cartridge to help improve the print quality. See this article for directions.
  2. When this step is complete, try to run the clean print nozzles (CPN) operation again.
Auto Alignment · Align the print cartridges
Align the print cartridges after installing them to improve print quality. To do this:
    2. Open the Lexmark Solution Center.
    3. From the Maintenance tab, click Align to fix blurry edges.
    4. Click Print. NOTE: Discard the page after it prints.
User the Quality Settings in Print Properties
Print Properties is the software that controls the printing function when the All-In-One is connected to a computer. You can change the settings in Print Properties based on the type of project you want to create. Do the following:
  1. With a document open, click File, Print.
  2. In the Print dialog, click the Properties (or Preferences, or Options, or Setup) button. The Print Properties screen appears.
    Click here for an enlarged view.
  3. Try changing the following settings to see if your print quality improves:
    Quality/Copies
    Quality/Speed
    Multiple Copies·Specify how the All-In-One should print several copies of a single print job: collated or uncollated.
    Print Color images in Black and White·Select this to print color images in black and white.
    Paper Setup
    Paper Type·Select the type of paper you are using, or allow the printer sensor to select the paper type for you.
    Paper Size·Select the size of the paper you are using, and specify whether or not you want to print borderless.
    Orientation·Specify how you want the document oriented on the printed page - portrait or landscape.
    Print Layout
    Layout·Select the print layout you require.
    Duplexing·Select this option when you want to print on both sides of the paper.
Save Settings
From the Save Settings menu, you can name and save the current Print Properties settings for future use. You can save up to five custom settings
I Want To
The I Want To menu appears when you open Print Properties. It contains a variety of task wizards·printing a banner, printing a poster, printing a photograph, printing an envelope, printing on both sides of the paper·to help you select the correct print settings for a project.
Check the Media
If the print is still blurry, try printing the same image on a different media brand/type: plain paper designed for use with inkjet printerscard stockgreeting cards, index cards, postcards, or photo cardscoated paperphoto or glossy papertransparenciesiron-on transfersbanner paper
Use the Lexmark Photo Editor
Try printing a higher quality image, or print an image from a different source.
Dec 20, 2008 | Lexmark Z611 InkJet Photo Printer
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
101 people viewed this question
Seeker5211
Seeker5211
