Question about Tally MT645 Printer
Bad ESC Seq
Hi my printer gives error me Bad ESC Seq, is a Tally MT645
    Novelist:
  • 169 Answers
The ‘Bad Esc Seq’ message on the MT645 indicates the printer is not recognizing some of the commands it receives in the data from the host computer system. These commends are sent in the format of Escape Commands Sequences hence the ‘Bad Esc Seg’ error message displayed on the printer.
There can be a number of reasons for the printer displaying the ‘Bad Esc Seq’ error.
The first thing that it may be worth doing would be to power the printer off then disconnect the printer from the computer system. Once the printer has been disconnected from the computer system power the printer back on again. If the ‘Bad Esc’ Seq’ message is seen when the printer is disconnected from the computer system this would tend to indicate there is a fault with the printer.
If the printer powers on OK and does not display any errors when it is disconnected from the computer system it is possible that one of two things is happening.
The first thing is that a print job has been sent to the printer using the wrong printer driver on the computer system, this will send data to the printer that it does not recognize. If this is the case the print job on the computer system would need to be cancelled and resent using a printer driver suitable for the MT645.
The other thing that may have happened is that the Emulation setting on the printer may have for some reason changed so the printer not longer matches the set up on the computer system. You may need to change the emulation setting on the MT661 so it matches the host computer system set up. The printer may need to be set to either Epson or IBM emulation depending on the computer system set up.
The Current emulation setting on the printer can be found by printing a configuration page, this can be done in the following way;
Put the printer OFFLINE
Press the MODE button
Press the DOWN ARROW until HELP is displayed
Press ENTER
The printer will print out a configuration page showing the current settings, this will include the Emulation setting. This can be checked to ensure it matches the computer system set up, or change to ensure the emulation is correct for your application.
If you are printing from Windows try printing using the Generic Text only printer driver, this will not send escape commands to the printer, so should print correctly. If you still see the Bad Esc Seq message I would recommend having a look into the connectivity between he printer and the computer system.
Posted on Sep 18, 2009
Hardware Alarm Wrong Board tally 2280
Hi Denis,you are having wrong board tally because you fixed the wrong part.pls check the part number and get a new one and fix it back.
Apr 11, 2014 | Tally Matrix T2280 Printer
Were is the web page for bt.com/signupmybt
where do I sign up to stop paper billing?
Apr 15, 2013 | Tally MT645 Printer
EXITING TALLY!! Internal Error. Contact Tally
My tally 5.4 not open when to try open tally when see exiting tally! file not found. Please give the solution immediately
Apr 27, 2010 | Tally T2245 Matrix Printer
Does anyone have serial pinout for mannesman tally mt645 printer.
Pin Signal
1 Chassis Ground
2 (TxD) Transmit Data
3 (RxD) Receive Data
11 & 19 (RTS) Request to Send
5 (CTS) Clear to Send
6 (DSR) Data Set Ready
7 Signal Ground
20 (DTR) (Busy) Data Terminal Ready
Feb 19, 2010 | Tally MT645 Printer
Error message bad esc seq
The Bad Esc error you are seeing indicates the pritner is reciving data from the host computer system that it does not recognise, the most likely cause for this error are;
  1. You are not using the correct pritner driver to print to the pritner
  2. The Emulation setting on the pritner is not correct, you can check this via the printers menu - I would guess the pritner has defaulted to MT660 emulation and it needs to be set to Epson or IBM emulation
Nov 17, 2009 | Tally MT661 Printer
Memory violation in tally 7.2 release 3.13
in some ledger we see the problem softare exception c0000005(memory access violation)
Dec 25, 2008 | Computers & Internet
Print stops after 2 pages !
Hi my tally printer 6218 giving Ribbon motion fault, what could be done to remedy this error message ?
Jan 19, 2008 | Tally T6218 Matrix Printer
272 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
