Want start unless you slam lid or push start knob in and out
My washing machine model LSQ9030PQ1 will not start unless you slam the lid closed or pull the start knob in and out several times.
    President:
  • 1,136 Answers
HI, Check and see if the door hinge screws are tight. Sometimes the hinge loosens and the lid switch will not activet properly. It the lid is tight, you might have a lid switch going bad. The lid switch is located under the control panel. There is a screw in each corner of the control panel in the back side. Loosen these screws and lift the control panel up and it will rest on the hinges.
Ths lid switch is to the left and should have three wire to it. Parts# 8318084
I hope this helps you. If I can assist you further or you need a place to order the lid swtich, please give my web site a chance at www.whirlpoolpartssurplus.com
Thanks
Vic
Posted on May 22, 2009
    Problem Solver:
  • 5 Answers
Your lid saftey switch is probably the problem. for a temporary fix.... remove the rubber gommet on your washer lid, its under the lid on the right side should be mounted on a white plastic "stick". the grommet is grey in color. if that solves the problem then your switch is going bad or you door is bent. if the door looks fine order nad replace the switch. or have a professional by to do it.
Washing cycle has finished but now the lid wont unlock. i have tried pulling the knob out then pushing it back in. i have also tried rewashing the load but now. not only will it not unlock, but it also...
you probably have a faulty lid switch/ locking mechanism. it is all in one. if the machine does not sense that the lid is closed properly, it will not start. you can try unplugging it to see if it will release the lid lock.
Oct 11, 2009 | Frigidaire FWS833A Top Load Washer
My washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Jul 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
A humming sound in the cycle knob
Make sure that the room is quiet then check that there is a clicking noise from the lid when it is nearly closed
If not then the microswitch is out of whack and needs adjusting
When you slam the door down it is probably enough to make the switch but then the machines movement will undo that action
Jun 02, 2009 | Kenmore 24032\24036 Top Load Washer
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The switch that makes it think it's closed is broken.
You are referring to the lid switch. If it's visible, try tightening the screws that hold it to the cabinet (they may be loose and the lid strike can't engage the switch properly). If you can, feel underneath where the lid switch is located and see if it's broken from where it mounts (feels loose). Push the lid switch lever down, if it doesn't "click" or doesn't start the wash, replace the lid switch and you should be good to go.
If you want, post your model number to make sure it's the model I'm thinking of and I can also try and get you the part number for the lid switch.
Mar 05, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Will not complete cycle
hi. i would check the lid switch fill the tub to low level let it start to wash stop the washer now put it to the spin cycle pull out knob close the lid slowly if it does not pump replace the lid switch now push on the lid. if it goes now .replace the lid switch .thanks te appliance doc. rate me please
Aug 22, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't start after lid is shut, if i slam it, it works!
sounds like your lid switch is loose ..look at the tab that sticks out of the lid and watch where it close's. inspect the switch see if it is loose or broke
Nov 28, 2007 | Washing Machines
Washing Machines Logo
276 people viewed this question
Top Washing Machines Experts
