Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Leak inside and outside of refrigrator
I am out of town, my roommate told me the refrigrator leak inside and outside...even after clean it. What do i need to do, is it difficult? Is it worth the fixing, what is the approx cost.
\pls help
  • yesllc May 30, 2009
    Thank you Vic, any assist will be greatly appreciate.
    It is a Whirlpool, Model ETCHXKQ0.
    President:
  • 1,136 Answers
Hi, it is worth fixing. There is a drain plugged in the freezer. Get me model # and I can assist you further on this matter.
Thanks
Vic
Posted on May 22, 2009
  • Victor
    Victor May 30, 2009
    I am sorry but, that # is not exact. Did you get it off the label inside the fresh food section? There should be some numders inside the letters
    ET12
    ET14
    Let me know
    Vic
Mitsubishi Eclipse AC leak & dealership cannot find the leak. Been in for service 5 times and dye is not showing leak. Any suggestions as to where it can be?
Your leak may not be coming from the outside. The AC has an evaporator tray that catches the humidity pulled from the air in the car drains it to the ground.. Sometimes the drain gets plugged up. Clear the drain and clean the tray. Sometimes that situation is accompanied by a nasty smell.
Mar 27, 2015 | 2007 Mitsubishi Eclipse Spyder GT...
Steam coming through ac/heater vents and outside windshield passenger side, I also smell antifreeze
sounds like you have a coolant leak from the heater core or a hose under the hood leaking you need help from a mechanic
Nov 27, 2017 | Ford Crown Victoria Cars & Trucks
A dealership fixed my cooling system. I was told it was an airpocket in the system. Now my ac only blows hot air. They keep putting me on hold and its hot outside. any ideas?
if the low side tube is cold while the compressor is working the problem will be on air door module, or one piece of hose from intake manifold go to recirculation door is dis connected, but if he compressor is not working, there is only two reason, even the refrigerant pressure is too high or too low, if low a leak on your system, if too high overcharge or clogged expansion valve or the condenser, if refrigrant is i the right pressure and compressor is not working, check the supply on main switch, ambient temperature sensor, refrigrant pressure sensor and the high pressure sensor, if all ok,. replace compressor
Aug 05, 2010 | 1989 Ford Crown Victoria
My motor is running, but the temperature is not cooling and everything is starting to melt.
The motor is running normally?so that mean there is no gas in the system,probably a leak of gas in the system,have you not smell the leak of gas?How old is the refrigerator?
Jan 25, 2010 | Whirlpool ED2FHSS Side by Side...
Not cooling
Roy,
Are the evaporator coils in the freezer frozen up?
The evaporator is located behind the cover in the back of the freezer.
If so this may be a defrost issue.
The adaptive defrost timer may have failed.
This is located in the ref. side inside the front control pannel.
If not then you may have a freon leak.
This would have to be repaired by a qualified technician.
Jan 15, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not cooling in freezer or fridge
first, check the coils under the unit and behind to make sure that the coils are clean. if they are, then make sure the fans are working. there should be one to blow air into the box and one to pull air out of the box. if they are working, and its a frost free model, then it may be stuck in defrost mode. lastly it could be low on refrigrant. If it had a leak, you would find small amounts of oil around the coils or compressor. the dust may even stick to the tubing due to the oil
Dec 20, 2009 | Freezers
Coolant reservoir empties and leaks onto the road and radiator is still full. this happens before it enters the radiator
The reservoir has a leak. Remove it, find the leak, and repair it. You can repair the leak with an epoxy sealer that you can purchase at any auto parts store. Mark the leak with a marker and then throughly clean the outside and inside of the container. Apply the epoxy to both sides.
Nov 26, 2009 | 1996 Jeep Grand Cherokee
My power steering fluid is leaking. The cars first owner told me that he used to put some leak stop and it worked for 1 month. But I want to fix this problem for good. Help me out please.
There can be many causes for a power steering leak, from loose hose clamps to failed seals inside the steering rack. The whole area needs to be cleaned down thoroughly and the leak source found and whatever the required repair is carried out from there. A power steering specialist is probably your best bet for speed and cost of repair, but you are best to get a few estimates around town and choose the shop that appeared the most helpful and friendly, not necessarily the cheapest.
Hope this helps,
Mark.
Nov 02, 2008 | 1988 Toyota Supra
Water builds up on the passenger seat floor when the a/c is running
the vent for a/c is block and leak inside it suppose to leak outside open the hood on the fire wall on passager side at the bottom you should see a rubber hose clean that hose its full of dirt you probably see water leak out that condensation from the evaporator (a/c) system hope its a fixya thanks pierre
Jul 31, 2008 | Mazda Protege Cars & Trucks
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
168 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
