Question about Kenmore Dryers
Dryer dosn't heat up.
I have a kenmore mdl. 110 98575820 stack-pack. The dryer dosn't heat.
  • ssv01 May 22, 2009
    I have checked the continuety of the heatinh element and it's OK.
    More please.
    Vern
    More please.
    Vern
    President:
  • 1,902 Answers
The heating element most likely failed and needs to be replaced. It cost about 25 dollars for it and you can do it yourself just remove the back panel unplug the machine and the wire have a adapter that can be removed by hand
Posted on May 22, 2009
Dryer not heating
Check Heating elements if ok check the in line fuse that go to drying element and if it open replace it and clean filter and check pipe that blow out side make sure it not stop up because if in line fuse is open stop up filter and pipe that blow air out side will cause the heating element in fuse to open up. And check for lose wire going to element to.
May 30, 2014 | Kenmore 98702 Stacked Washer/Dryer
DOes not time out nor does it heat, mdl 66512610 electric dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 14, 2011 | Kenmore 65942 Electric Dryer
Change thermostat, tested heater coil, dryer still won't heat on a Kenmore stackable
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer doesn't heat.
you have to remove the panel between the washer and dryer to get to it it is the smaller fuse on the heater box-mike
Feb 07, 2010 | Kenmore Dryers
No heat in my stack-pak kenmore dryer. The element is ok and there are no broken cables/wires. 220 does come in to the unit and show up at the componets.
There is a thermal relay switch that is blown. Replace it.
Model number please and I will give you the part number.
May 23, 2009 | Kenmore Dryers
Dryer not heating up
check your air flow coming out of dryer if it is good and stong then you should change the high limit safety thermostat and the cycling thermostat.
Apr 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water leak from washer
The element is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer door
I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
Aug 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer no longer heats up on my Kenmore 417.94812301 laundry stacked unit
On your dryer the common problems found is either you lost some of your electrical power (check your fuse box) or you need a new heater #131475300 about $100 for the part.
Jul 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
