Question about ASUS P4P800 SE (890552603657) Motherboard
Bios error at bootup i get the new cpu installed! message randomly after every boot but have not installed a new cpu been using the same one and motherboard for 2 tears never had problem before
    Scholar:
  • 155 Answers
It could be a low CMOS battery. Please replace it and let me know.
Posted on Oct 19, 2007
Acer Aspire X3200 - VIRUS - Won't boot or re-install
it seems like the HDD is not getting recognised , try this might help you get into BIOS setup by tapping delete key or f2 when system turns on , load the defaults settings for bios then try loading OS , if you are getting the same error message that means hdd has gone bad or the cable to the hdd is loose
Jun 29, 2010 | Acer Aspire X3200 PC Desktop
Compaq Presario S5300NX (DM174A#ABA) PC Desktop: Compaq Presario Dekstop: CPU Fan error on bootup. ...
The fan has a third wire, that is used to tell the uProcessor that it is spinning and in some cases how fast.
Replace the fan and that should fix it. Spares form many suppliers on ebay
May 18, 2010 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
Operating sysmtem not found. Cannot re-install either. Blue screen saying to disable shadowing and cacheing in BIOS!!! Cannot access F8. Installed new hard drive and the same message.
If you have a new hard drive,it must be formatted and the OS must be reinstalled upon it. You are getting this error because there is no OS on it currently, according to what you are telling us here.
thanks for using FixYa.com
Positive comments are always welcome
a
Oct 27, 2009 | Computers & Internet
Boot disk error insert system disk and and press enter.
it is a hard disk error. most likely your hard disk is defective since is it not registering well. please try to use 80-pin interface cable to correct the problem or change your Hard Disk
Sep 21, 2009 | ASUS P4S533-MX Motherboard
Error Message on 1st page boot up
Hi Chris,
Reset the bios jumper on the board. Use your manual, go to the bottom of page 9. Please unplug the power cord from the PC.
Clear the cmos/ bios & remove the bios battery as well. (You may use a small flat tip screw driver to help lift the battery out). If you have a voltage meter check the battery for 3volts DC. (If you have a voltage meter suggest you check the battery for 3volts DC while its out).
Re-place the bios battery & reset the bios jumper back to Normal. Re-connect the power cord to the PC. Boot the system & enter the bios menu. Adjust all your setting as needed.
(DO Not over-clock anything)!
If you still receive an error message your only other option would be to flash the bios. Even if you have the latest bios software already installed. The current bios software may be corrupt.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=537&CategoryID=1&DetailName=Bios&MenuID=48&LanID=0
Good luck Chris!
Mike
Nov 06, 2008 | EliteGroup RS482-M754 Motherboard
Frezes at verifying DMI settings. Already changed MB and Power supply. Lan connection only flashes green once in a while should be constant. Tried on a working terminal and does the same.
The Desktop Management Interface (DMI) is a new
method of managing computers in an enterprise. The
main component of DMI is the Management Information
Format Database, or MIFD (the DMI Pool Data). This
database contains all the information about the
computing system and its components.
At times, some systems may experience hang
conditions after partitioning, formatting and initial
bootup of a hard drive. The message, "Verifying DMI
Pool Data" appears and the system hangs. This
condition may continue after the drive has been
removed.
! WARNING ! ALL SUGGESTIONS LISTED IN THIS
INFORMATION BULLETIN ARE BIOS RELATED. FOR
A PERMANENT SOLUTION, MAXTOR RECOMMENDS
THAT USERS CONSULT THEIR SYSTEM OR
MOTHERBOARD MANUFACTURER FOR BIOS
UPGRADES.
Suggestions to Resolve the Condition:
1.Apply power to the computer.
2.Access the system BIOS.
Set the drive type as None or Not Installed.
Load BIOS Defaults
Load SETUP Defaults
3.Save the BIOS changes and reboot the PC to a
System Boot Diskette.
4.Shut down the PC after the memory count is
displayed.
5.Reconnect the power and interface cables to the
hard drive.
6.Access the System BIOS.
7.Auto-Detect the hard drive. Ensure that the LBA
Mode option is enabled.
8.Save the BIOS changes and boot the PC with a
System Diskette.
9.Partition and format the hard drive via the
operating system.
10.Reboot the system. On bootup, the screen should
read:
Verifying DMI Pool Data
Update Successful
The system should continue booting normally.
Other Possible Solutions:
2.Access the System BIOS.
3.Disable both the Internal and External CPU Cache.
These features are located in either the "BIOS
Features" or "Advanced Settings" options of the
BIOS Setup.
NOTE: Consult the System or Motherboard User's
Manual for exact location of the Internal and
External CPU Cache settings.
4.Save the BIOS changes and reboot the PC to a
System Boot Diskette. On bootup, the screen
should read:
Update Successful
5.After the system successfully boots, re-start the
PC and access the system BIOS.
6.Enable the External CPU Cache. This feature is
located in the "BIOS Features" or "Advanced
Settings".
Manual for exact location of the External CPU
Cache setting.
! WARNING ! User's MUST re-enable this feature
for optimal system performance.
7.Save the BIOS changes and reboot the PC to a
should read:
Update Successful
NOTE: If the aforementioned suggestions fail to
resolve the issue, contact the system or motherboard
manufacturer to:
Remove the "Clear CMOS" Jumper and reset the
system BIOS
Obtain a Flash BIOS Upgrade
from pc help;
SYSTEM HANGS AT MESSAGE: "VERIFYING DMA POOL DATA":
You did not say what operating system you are running but I assume Windows 95 or 98. It is possible some Windows
system files are corrupted or perhaps the system doesn't like your ram (if you added or installed ram recently). There
is also a possibility that there is something wrong with your BIOS and you *may* have to update it, but I would avoid
doing that if at all possible.
A quick fix - if the problem is software related - is to:
1. boot to a Windows startup disk (one that matches your operating system). this step assumes that your PC is setup
to boot to the A: drive before the C: drive (via the BIOS SETUP program). If you don't have a Windows startup disk,
you will have to make one on another person's computer that has the same version of Windows. You make one via:
my_computer/control_panel/add_remove_programs/startup_disk
2. run "scandisk c:" to make sure that any file corruption is fixed before going to next step
3. do a "sys c:" from the "a:" prompt to transfer a good copy of Windows system files to c: drive
4. remove the boot floppy, reboot the system and see if all is well.
If that does not solve the problem you may have to reinstall Windows 95/98. Ouch!
I recently had someone bring me a computer that had this DMI error message problem and I tried the "sys c:" method
(with the startup disk) without success and had to entirely reinstall windows 95 (and almost all applications except for
some programs that did not need to be placed in any Program Files directory or other special location) to cure the
problem. However nasty a job that is, it did cure the problem.
Jun 23, 2008 | Computers & Internet
HP Compaq Presario V6000T
what you need to do, is go into the Bios. usually F2 at setup.
Or esc or delete. you have to press a few times at bootup.
Once in the bios screen, find the page where you can change the boot sequence. it,s probably set to boot from HDD( hard disk ) set it to boot from CD/DVD first then FDD Or HDD second.
when you save and exit, it will boot from the dvd drive, this will give you access, to use the cd drive first.
then re-install your operating system.
Mike @ compurepair.
Apr 04, 2008 | HP Compaq Presario V6000T Notebook
No Booting to BIOS, Monitor just stays on Save
If there are no beeps at all on boot up it's a memory timing problem, Go into bios in standard bios settings menu and disable 'Halt On All Errors' if it isnt already, this may show up the problem in the initial power on self test.
Oct 26, 2006 | Abit SG-80 Motherboard
Fan error during boot-up
Power supply, that can be the cause. Did you try disconnecting few devices to check if the CPU fan has enough power to turn itself on. Usually motherboard will have two connectors for the CPU fan, you may try connecting it directly to the power supply. Also Check through the BIOS and see if there is a setting to disable the CPU Fan monitor (Hardware Monitor??) It should be where the temps and voltages are. The BIOS in most computers has an option to monitor a CPU fan. If none exists, then the option needs to be disabled. I am assuming the error is occuring during the BIOS stage of bootup. If the error occurs in Windows, it may be that some software has been installed to monitor a fan that doesn't exist. Sometimes monitoring software comes on the motherboard CD and someone may install it, thinking it is a driver. It is not necessary. Good luck!
Jan 13, 2006 | HP (D9820-60007) Motherboard
ASUS P4P800 SE (890552603657) Motherboard Logo
123 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
