Question about Kenmore 16622 Mechanical Sewing Machine
Where to I oil this machine
Where to I oil my old Kenmore model # 158 13410?
Get a good quality sewing machine oil, not general purpose oil as that will gum up over time.
If you don't have a manual, a good rule of thumb is to oil everything that moves, but lightly. Don't oil the motor or belts and use lubricant (usually sold in a tube), just a little dab, for the gears. The same with oil, just use a little bit and then move the machine by hand and you will see where the parts move.
Take off the top to see all the moving part and don't forget to oil underneath the machine as well.
You can find manuals for sale on a number of online sights and manybe even Sears.
Patience
Posted on May 24, 2009
    Problem Solver:
  • 16 Answers
This is one of those deals where they don't want the average person inside because they can do as much harm as good with the wrong lubricants, and putting excess of it which just attracts dirt. However if you expect your machine to last, just putting machine oil on the bobbin axle every week isn't going to do it. I've got my 7 years old Brother LS-1217 cracked open because I felt it was running a bit noisy lately, and I'm an ex Navy Aviation tech who knows nearly everything loves grease, but it must be done right.Your Kenmore is probably built similar- First understand you don't want to go spraying any light solvent type things like WD-40 in there as it just eats away what little grease or oil it is still there. You also are looking at at least 3 kinds of lubricants, if it's metal on metal moving parts a white grease, probably lithium based, you'll see that on many rotating parts. Next, and this is very important, if there are parts made of white nylon/plastic they must have have a special lubricant. If you drip excess grease or machine oil onto those parts they will eventually be eaten by it. This is why you must take the case apart to properly lube these machines, and shouldn't go trying to spray or drip oil haphazardly, hoping you might do some good. Finally you do need to remove as much excess as possible as the cleaner they stay inside, the better.
I will tell you though, if you understand what I've just explained, there are dozens of moving parts inside these that if not kept lubricated will surely wear and get sloppy.
Just know what goes where and not make a mess, and don't allow the wrong lubricant to drip where it shouldn't be.
Posted on Jan 03, 2010
I need a manual for a Kenmore sewing machine model # 158.12410
Sears carries manuals for most Kenmore machines. Even if they may not have your exact model, machines operate much the same, so a manual for a similar model would be helpful.
FWIW, my first sewing machine was a model similar to yours. A real keeper--wish I would have kept mine. However, your machine, being mechanical, does require frequent cleaning and oiling. These good old machines are often forgotten, but it would be well worth your time to give it some TLC to keep it running smoothly.
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
Nov 11, 2017 | Kenmore Sewing Machines
How to thread kenmore sear roebuck sewing machine model 158. 1789181 got at auction no books
Sears carries a lot of manuals for their machines, although usually not free. In the meantime, there are many threading videos that demonstrate machine threading. Machines of similar models will thread similarly.
Threading mom old kenmore sewing machine
Kenmore 158 17550 Sewing Machine Tutorial
Probably best to raise the presser foot when threading so the thread will seat in the tension disk.
Before trying to sew, be sure to oil your machine with fresh, good quality sewing machine oil. Open the top, the side near the needle bar, and turn it on its back to get the underside. Place a couple drops of oil every place that metal rubs on metal. Adding hot air from a handheld hairdryer will make the oil effective quicker.
Be sure to install a brand new needle and use good quality thread--not old or bargain bin variety!
On the top left, there is probably a push button. This is the presser foot pressure adjustment. When the machine is stored, this pop-up button should be released (press down on the outer ring). Being stored with the pressure full on will eventually compress the spring that provides the pressure. Also, be sure to store the machine with the presser foot in the down position (preferably on a piece of scrap fabric). Avoid running the machine with the presser foot in direct contact with the feed dogs as this will wear the feed dogs and also create grooves in the presser foot.
Kenmore 158 1601 Sewing Machine Cleaning oiling and Maintenance
Jul 29, 2016 | Kenmore Sewing Machines
Kenmore sewing machine model 158.12260 Manuel
Sears carries many manuals for Kenmore. That's probably the best place to check--unfortunately, they generally are not free.
The sewing machine could probably use a good cleaning and oiling. These old (but great!) mechanicals need 1-2 drops of fresh, good quality sewing machine oil (Tri-Flow Synthetic Oil works great!) every place that metal rubs against metal. NO oil on plastic, nylon, rubber, or belts!!! Simply open the machine's top, left side, and free arm cover (if not a free arm, you'll need to access the underneath of the machine). Gently hand rotate the handwheel toward you and apply a couple drops every place metal rubs metal. Don't forget the lever & dial mechanisms too. Probably, in your case, the bobbin winder mechanism (do NOT oil the rubber tire!). Then you can apply hot air from a handheld hairdryer into the mechanism to help free it up.
Jun 23, 2016 | Kenmore Sewing Machines
I have a Kenmore sewing machine, model # 385 15358600. The needle quit moving when I press the pedal. But, it will move if I turn it manually. How can I fix this?
that might indicate a new foot pedal is needed . these newer electronic ones fail where as the old carbon resistor type kept on working for decades
May 26, 2015 | Kenmore Sewing Machines
Bobbin rewinder won't work
it's possible that there is a part inside the machine that could be broken, it would be a good idea to have the machine checked.
Jun 23, 2013 | Kenmore Sewing Machines
4t year old kenmore sewing machine model 52 has always worked fine. I use it all the time. Zigzag seems stuck and wont move back and forth after oiling. Don't know if oiling had anything to do with it. Has...
maybe a service call is in order. I have a 30 year old huskavarna can't spell it, but the repair people said they don't make the machines out of metal anymore so if you have one you liked it is worth the 200.00 of it needs a new part, and they clean them really well as well, good luck hope it works K
Sep 21, 2017 | Kenmore Sewing Machines
Kenmore 385-16627 slowing down--where do I oil?
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/385_10.html
If your machine is computerized, oiling could be damaging if done improperly. It may be worthwhile taking it for service.
http://www.searspartsdirect.com/partsdirect/part-model/General-Parts/Humidifier-Parts/Repair-Maintenance/Questions-Answers/Kenmore-385.-12116690,-hand-wheel-stuck/Model-45/0431/0913000/335765?modelNumber=45
Mar 19, 2017 | Sewing Machines
Kenmore 10 Sewing Machine
i have a kenmore10 model 1249180 ehwn i sew it squeeks i oil it i dont know where the squeek is coming from
Dec 05, 2007 | Kenmore 744-08BH Mechanical Sewing Machine
Sewing Machines Logo
288 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
