Home | Acer | N300 Pocket PC | Two MC50's that won...
Acer N300 Pocket PC
Problem for Acer N300 Pocket PC
Two MC50's that won't turn on.
By melaniepears on May 22, 2009
I have two MC50's that never turn on. They do seem like they are charging as the light on the system docked is orange, and the battery from the other charging is orange. I have only had them plugged in for a few mins so I don't know if it should turn green anytime soon. Even after a short charge though they do not turn on or show any signs of life. I've pressed the power button, and reset button, and all other buttons. I'm out of ideas and the users are getting pretty anxious to have them fixed. Are they fixable and how?
Solution #1
posted on May 28, 2009
Not Rated)
richard_bown
Rank: Guide
Rating: 92%, 3 votes
Check the battery latch on the rear isn't switched to the wrong position, also the lock switch on the righthand side.
If this doesn't work they may need a full charge to turn on. Leave them on charge overnight if you can.
If they still won't tun on try a cold reset - hold power button right hand scan button and press the reset button on the back at the same time (this may take a couple of go') but this WILL destroy any data on them and return them to factory config. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Acer N300 Pocket PC
Questions and Unsolved Problems for Acer N300 Pocket PC
Do you recommend Acer N300 Pocket PC?
Answer
Answer
What settings do I have to enter into the N300 to connect to the internet through my home wifi... (More)
Answer
cannot connect to the internet using a wireless connection.
Answer
acer n300 turn off if remove from power ( charging ) i don't know its'"s battry problem or... (More)
Answer
I guess the joystick of my n300 is having problems, Is there a way to cancel it using a trick in the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer N300 Pocket PC:
Top PDA Experts
Rank: Guru Guru
Solutions: 551
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
