Question about Philips Magnavox 27MS343S 27" TV
Horizontal line in the middle of the television
I have a Magnavox 27 inch television set with just a horizontal line in the middle when turned on. The sound and even the channel changer works. I would like to know if this is a costly repair, or is there something that I could do to fix this?
  • 1 more comment
  • Anonymous Feb 04, 2008
    where could I get someone to fix this problem ? Best buy Circuit city ??????
  • LJT12345 Feb 04, 2008
    Where could I get this problem fixed ?????
  • lachaun Jun 22, 2008
    I have a 27MT3305/17 27inch Magnavox TV. Had it for 2 years. for the last 4 weeks I have been watching a black horizontal line at the top of my TV screen grow wider and wider. I is now around 4 -5 inches wide vertically.
There's a burned mark on the circuit board takes about 10 min ti fix cost aroun 100.00
princehaynes@bellsouth.net
Posted on Sep 22, 2008
  • 4,889 Answers
From your description of the problem, there seems to be a Cold solder in the Vertical Oscillator or Deflection Coil circuits.
If you know Solid State electronics, and are good with a soldering Iron, sure u can do this yourself.
U gotta trace the Vertical section components and locate the cold solder. In most cases it will be a loose connector from the Deflection coil to the main PCB.Also check for the soldering of the Vertical output IC.
Posted on Oct 19, 2007
  • eagle338
    eagle338 Oct 19, 2007
    I checked out with my friend's tv the exact Location of the problem:
    On the CRT circuit board(picture tube), you will find R3340, which is a
    10 ohm 1/3w resistor. The location of the resistor is printed on the
    bottom of the ckt board. It is burned open, replace with a 10 ohm 1/2w
    resistor. This will solve your problem. The original resistor was sized
    too small, should have been a 1/2 watt.
    This resistor is mounted
    standing up on ends. Mount the replacement resistor the same way. You
    can probably get the resistor at your local Radio Shack. You will
    probably have to buy a package of 5, but what the hey . . . they are
    cheap.
    Be careful and don't get the circuit trace too hot and damage it
    Genius:
  • 1,694 Answers
Tnewk, Your symptom is no vertical deflection = check for
B+ voltage present at vertical output IC.If present = replace IC.
If missing, check B+ power supply............T.
Note: 10 ohm resistor replacement symptom = No video,
lit white screen with retrace lines ...........T.
Posted on Nov 08, 2007
2 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: Horizontal line in the middle of the television
Hello RENE1223,
Normally this is not a costly repair. This is because it could be the vertical coupling capacitor. However if it is the yoke transformer it could get costly. There is no way for you to repair this problem if you do not have a background in electronics. So I would suggest taking the TV to a repair shop to get an estimate. If the estimate is within the range you are willing to spend let them fix it.
I hope this helps,
thank you,
Shuttle83
Posted on Mar 26, 2008
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
My tv will turn on but with white light line then shut off itself
If the line is horizontal (it is a vertical problem) If its a Vertical line (it a horizontal problem) So it could be just a bad solder joint or a component has failed in the horizontal or vertical section. Hope this is helpful.
Nov 28, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
RCA 27 in has white horizontal line going through the middle
this symptons is caused by a breakdown in the vertical deflection circuit. hence, the trouble may be in the vertical oscillator, amplifier or output circuit. in most modern tv the vertical ic is usually composed of these said circuit inside. the ic have many pins, standing on a heat sink and smaller in size. try to check also the capacitors surrounding it. sometimes leaky capacitor may cause this problem. good luck!
Aug 16, 2009 | RCA TruFlat 27F520T 27" TV
Single horizontal line
this problem is field collapse usually causd either by the field oscillator or field output stage to advise you further i would need to look at the circuit diagram
Feb 09, 2009 | Philips Magnavox 27MS343S 27" TV
White horizontal lines in my 27 in Phillips Magnnavox tv
I have seen this on mine. Check the cable going into your TV and make sure it is good. The ground portion of the cable could not be making a good connection.
Jan 17, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox with a white screen, sound, volume and channels working
dont put in back the vertical prossesor ic get a new one and solder it in see what it does.good luck.
Aug 19, 2008 | Philips Magnavox 27MS343S 27" TV
Look maybe if you resolder vertical IC you will repair this set ,Or replaced it. But a lot times just need be re solder. Thank you
Aug 19, 2008 | Televison & Video
Magnavox 27 Inch TV- no picture but has sound
the vert. circuit need to be rebuilted
Aug 04, 2008 | Televison & Video
Hello RENE1223,
I hope this helps,
thank you,
Shuttle83
Mar 26, 2008 | Televison & Video
Philips Magnavox 27MS343S 27" TV Logo
2,646 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
