Question about Panasonic CT-35G25 TV
Pvr5263rk The tv was working properly, then there where no video but there is audio. What could be the problem? Thank you
  • 4,889 Answers
There is a problem in the horizontal sweep section of the circuit...usaully a dry solder causes this problem check for dry solders and re-solder with  8mm lead solder wire..
Posted on Oct 19, 2007
SOURCE:
No problem - I hope!!!! Just need to know if Direct TV is compatible.
Direct TV is compatible with all TV's. Just requires the proper cable connections
Mar 10, 2011 | Televison & Video
SIR, PLS TELL ME IN WHAT WAY INPUT VIDEO SIGNAL TO PC FROM USB PORT WITHOUT USING TV TUNNER CARD, PLS GIVE THE PROPER SOLUTION. THANK YOU.
You need to buy an EasyCAP DC60 - USB 2.0 Audio/video Creator Capture High-quality Analog Video from AMAZON for less than $10.00.
Feb 12, 2011 | Televison & Video
I have no TV output!
This will only work with a dvd player, PS3, XBOX 360, and other gaming consoles
You need:
- 3 AV Splitters (2 Female 1 Male sides cord)
- 1 Double sided Video and Audio Cables (Red, white, yellow cables)
Connect your consoles Video and Audio cables to the female sides of the splitters, next attach the Video and audio cables you bought to the splitters as well.
Now plug in the video/audio cables you bought into your TV.
If you did this everything properly this should work.
Sorry if this didnt help you
Mar 25, 2010 | Pinnacle Dazzle Video Creator Platinum...
Problems with Audio and Video cable
there is a switch on the base of the cable labeled HDTV and TV, move to TV for normal cables.
Dec 06, 2009 | Microsoft Xbox 360 Console
Need a red bulb for Zenith PVR5263RK rear projection tv
It sounds like your looking for a CRT (red) the part # is on the CRT and could be puchased through any Zenith (LG) distributer- usually around $300- $500. Google the part # when you get it and you may find a used Picture Tube (CRT)for cheaper.
Sep 22, 2009 | Zenith R57W46 57" Rear Projection...
Hook cable box to this receiver
I have similar situation with my TXDS 565 and could not video out of my unit after hooking up the cables properly in and out of the unit for all auxilary modules... I assume that you have tried to place your vid IN from the cable box to your units vid IN and run a vid OUT cable or S cable to your TV. If this doesn't work for you as it did not for me, then you must run your cable direct to the TV vid IN and run your audio out from the TV audio Out back to your reciever as audio IN in the Video I or II ports on the reciever unit. This will give you audio control through the rec. unit.
I suspect that my is damaged and will not function properly; yours may be too,
My unit is about 10 years old and repair is too expensive so I will run it this way until something else fails and I will replace it... probably not Onkyo.,'
Let me know if I clearify any of this.
Jan 02, 2009 | Onkyo TX-DS575 Receiver
No service
  • Make sure that you have connected the cable box properly to the TV.
  • Use the audio and video OUT from the box to the TV IN.
  • Select the correct input on the TV.
  • Connect it using any of the following: A HDMI cable (1 cable for both audio and video), Component Cables (3 RCA's red, green, blue) + RCA audio cables (1 for mono or 2 for stereo), S-Video + RCA audio cables (1 for mono or 2 for stereo), or AV cables - 1 RCA for video (usually marked yellow) + RCA audio cables (1 for mono or 2 for stereo).
  • Consult your TV's owner's manual for detailed instructions or ask me for more information.
Hope this helps. :)
Apr 01, 2008 | Televison & Video
Cannot view channels higher than 10 and cannot get DVD to come on
Dear althea, I cannot help you with the first problem, but as for the second, "DVD does not come On" and "Do not understand Video 1, 2, & 3 settings." it is very simple. YourTV has the sockets at the front Marked Video 1, Audio L and audio R, The y are in three colors - Yellow for video, red for audio right and White for Audio Left. Similarly, you have 2 such sets of 3 sockets - they are Video 2 and Video 3. This allows your TV to be connectod to three different Video sources - maybe a VCR, A Video game, and a DVD player. To view the pictures generated by your DVD Player, all you gotts do is connect the supplied AV cord from the rear of the DVD player to the front three sockets in the proper order - Video from DVD to Video of TV, Audio L & R from DVD player to Audio L & R of TV. Now press Video on the TVs remote. Press repeatedly till you get Video 1 displayed on the screen. Then, if you now play your DVD player - make sure there is a disc in it - you will be able to view the picture / movie. Good Luck
Mar 05, 2007 | Sony KV-32XBR100 32" TV
How to input audio with capturing the video?
The white and red leads off the VCR are typically audio, the yellow is video. I would suspect the problem is elsewhere. The cards capture software is a likely candidate.
Feb 08, 2007 | KWorld (KW-L883D) (KWL883D) Video Capture
Televison & Video Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
