Question about Refrigerators
Evaporator fan has stopped working
A green "grounding" wire was disconnected when we were trying to repair our refrigerator, and now the evaporator fan has stopped working. Any suggestions? Thank you
    President:
  • 1,136 Answers
Check and make sure the other two connections are solid.sometimes when the fan gets unplugged, the terminal gets loose and looses connection where it is soldered into the fan motor. Some models need to be a certain temperature in order for the fan to work. You can check voltage to the fan also. There should be 120V to the fan. Makes sure the fan/light switch is pushed in (on some models). If I can assist you further, please let me know.
Thanks
Vic
Posted on May 22, 2009
    Problem Solver:
  • 5 Answers
Many evaporator fans are thermostatically controled and will not restart until the evaporaator temperature reaches 22 deg. how long has it been running since you replaced it?
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Help reconnecting Acceler-ice 3xi icemaker in Kenmore Elite 106.74206400
if the wire is green i would suspect it to be a safety ground yo attach where the fan mount attaches to the body of the refrigerator. this is assuming the original fan only had a two wire hookup. Ed
Dec 24, 2012 | Kenmore 21.7 cu. ft. Top Freezer...
Frigidaire GLRS264ZA refrigerator keeps blowing GFI circuit
The fan and defrost heater are run off the same relay on the board. When on defrost, the fan stops. when the fan starts, the defrost heater is switched off, Sounds like the neutral to the board may be shorting. If you have the ability, try powering the evaporator fan from the compressor relay, disconnecting from the board entirely. To see if this will work, just take a temporary wire to the fan when disconnected and see if it trips while running.
Aug 07, 2012 | Refrigerators
Ammana Fridge-Evaporator Fan not working
Replace the defrost bimetal . On older Amanas' , the coil has to be cold , before the evaporator fan starts ( bimetal closes ) . This way , heat from the defrost cycle , will not be blown into the refrig section .
Oct 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Compressor in fridge not working. Freezer is working fine. Is there a reset button? What steps can I take to see if this is a simple issue?
There is one compressor that serves both the freezer and refridgerator compartments. You need to confirm if the evaporator fan in the freezer compartment is working. When you open the door to the freezer, you should see and hear the evaporator fan in the freezer compartment running. Particularly if there is a demand on the unit through the thermostat setting. If the evaporator fan is not operating, you can check the evaporator fan motor with a volt meter to see if it's getting power. If its getting voltage, but not operating, you need to replace the evaporator fan motor in the freezer compartment. There are 3 wires that attach to the evaporator fan motor. One hot wire, one neutral wire and one ground wire. The ground wire is usually marked green, the voltage wire is usually marked black and the common wire is usually marked white. You should get a reading on your volt meter of a voltage from the hot post to the neutral or from the hot to the ground. If it is getting power but will not operate, then it is definitely a bad fan motor that would need to be replaced.
Oct 04, 2009 | Refrigerators
Freezer not freezing fridge not cold, freezer frosted up
Oct 03, 2009 | Refrigerators
FREEZER WORKS, REFRIGERATOR DOES'T
Refrigerator trips GFI outlet
unlikely to be the defrost timer. more likely to be the defrost element. try disconnecting the element and see if it trips then. could be of course a wiring fault - frayed wires etc
Jun 18, 2007 | Viking VCSB423 Side by Side Refrigerator
Refrigerators Logo
217 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
