Question about Brother MFC 7420 All-In-One Laser Printer
Recieve multiple paper jams that wont stop!
Have recieved multiple paper jams and will not stop!! Can not seem to figure it out - on MFC 7820N
  • Yuk-Wa Chan May 11, 2010
    where's jam?
    Front or back or in the drum?
    Problem Solver:
  • 4 Answers
Is there a sensor flag that is stuck and/or broken?
Posted on May 22, 2009
Paper jam displayed but no paper jam found. Cleaned with air but this did not help. Seems like printer wants to keep resetting itself.
I had this problem and someone on Fixya solved it. Open the back cover and slide the guide slightly. If it's off center it won't work and gives you the jam message even though there's no jam. It solved it instantly.
Sep 27, 2011 | Brother MFC-7820N Printer
My Brother MFC-7820N has a paper jam problem that seems to be related to it's picking up an additional sheet of paper and when the first sheet completes it's print pass, the second is midway and the...
most paper has a smooth side and a little less smooth side, try flipping the paper. in the pack use the top side as the printing side when u load. try a different brand of paper could easily correct the problem,
some feed trays work best when nearly full also, try half full etc.
Oct 10, 2010 | Brother MFC-7820N Laser Printer
Our Brother 7820N all of a sudden started paper jamming. Took everything out and it still jams. What can I do.
Try the link below, if its not working that may be a hardware issue and needs repair: 7820n Paper Jam
Aug 26, 2010 | Brother MFC-7820N Laser Printer
MFC-7820N Paper Jam On Exit After Fuser
Hello, I can solve your problem for $50 plus shipping.
Jan 12, 2010 | Brother MFC-7820N All-In-One Laser Printer
How do you remoce the drum to clear a paper jam on
Lift the top, remove the toner and open the access panel in the back, remove the printer tray. You should be able to see the full path the printer takes from start to finish. Rarely do you need to take anything else apart. If these areas are clear as the printer will attempt to clear jams when you start it up.
Nov 08, 2009 | Brother MFC-7820N Printer
Cannot send or receive faxes
Try to call from your fax if u make calls then the line is ok,if not check the line.check the cable have 4 pin ,Take the user settings in the reports menu,check and confirm the mode is "tone" if its "pulse" change it as Tone.
May 05, 2009 | Brother MFC-7820N All-In-One Laser Printer
Continual paper jams in rear of printer
If the paper is jamming at the exit rollers, you will be need to clean the rubber on the rollers. It gets shiny and does not grip the paper to take it away.
Jan 03, 2009 | Brother MFC-7820N Printer
Back cover open message on brother mfc 7820n
Had same problem. Closer inspection revealed bit of paper out of sight. Removed the toner cartridge and worked to free torn paper. Then restart. Hope it helps.
Dec 15, 2008 | Brother MFC-7820N Printer
http://www.fixya.com/support/t150137-one_more_person_back_cover_open_problem
Oct 24, 2008 | Brother MFC-7820N Printer
Scanning multiple pages
Use paper port software which is part of brother software suite but under different menu (check out under start - programs - paperport
Feb 05, 2008 | Brother MFC-7820N Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
289 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
