Question about Microsoft Xbox 360 Console
My xbox 360 has 3 flashing lights?
I have already unplugged and replugged everthing back up. what else can i try??
  • 6,784 Answers
  1. Try restarting the console.
  2. If restarting the console does not resolve the behavior, follow these steps:
    • Turn the console off.
    • Unplug all the power and AV cables from the console.
    • Unplug the power cord from the wall socket.
    • Firmly reconnect all the cables.
    • Turn on the console.
  3. If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  4. Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
Now, if the above troubleshooting tips don't yield results, i recommend using the link below to combat this issue further.
CLICK HERE
Posted on May 22, 2009
My xbox is flashing red lights i think its overheat what can i do
flashing red lights is a sign of a power supply problem try unplugging all electrical cords and replugging them (including to power supply box)
Jan 15, 2011 | Microsoft Video Game Consoles & Games
Red flashing light and having a code E73
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit www.xbox.com/support
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
http://forums.xbox-scene.com/index.php?showtopic=484726
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
Sep 06, 2010 | Microsoft Xbox 360 Pro System Console
I took my 360 apart because my brother got it from an the expo center (it had no warrenty) and i got the E73 so i overheated it by unpluging the fan on the inside. i waited and then turned it on it was...
The Sticks Method:
Jun 27, 2010 | Microsoft Xbox 360 Console
What do i have to do to fix error code E73
The Sticks Method:
Apr 24, 2010 | Microsoft Xbox Console
My xbox keeps saying e73 can you help
The Sticks Method:
Apr 02, 2010 | Microsoft Xbox Console
E73 xbox
The Sticks Method:
Apr 02, 2010 | Microsoft Xbox 360 Console
How do i fix my xbox 360 e73??
The Sticks Method:
Feb 05, 2010 | Microsoft Xbox 360 Controller
I ned heip on my xbox 360?
htgfxdsghfxzgxdrgfdczfgdcgfdgzfdgrzfdcgfdgfdzxcrfszdrgfdzcgfdFSDEFSDZFSDCFSDFSDFSDSFDDDDD
May 02, 2008 | Microsoft Xbox Console
1 red flashing light
Hello Lexie1,
According to Microsoft Support, what you are experiencing on you 360 is an hardware failure and Microsoft support suggest that you contact them for further assistance.
Here is a link that should assist you further.
http://support.microsoft.com/kb/941377?sd=xbox
Sincerely,
Agent Xiong
Apr 29, 2008 | Video Game Consoles & Games
Xbox not reading game
I don't know if this will help anyone, but I have tried a variety of things that occasionally have worked. Eject disk and pop it back in and then restart 360. Sometimes may require doing this a couple of times. If that doesn't work, try unplugging that thing in back with the orange light and replug it. Or simply, as it worked for my brother, just turn the 360 off and unplug the orange light thingy and don't play again until maybe a week or month, etc. He unplugged it for about 3 weeks and then it worked perfectly again. Sometimes the 360 just needs a little break. Even though this may be impossible for most to leave it alone for even a day, but its either you or your 360. make it live again!
Jan 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
66 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
