Home | Washing Machines | Kenmore Washer Water Lea...
Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Kenmore Washer Water Leak
By kpholloran on May 22, 2009
I have a Kenmore washer that's leaking at the very beginning of a wash cycle. Model 110.82692120 circa 1987. I had a similar leak a couple years ago from a split hose, so was thinking along those lines but all the hoses look pretty good. I reconnected the dry detergent dispenser water hose to its valve outlet and stuck the open end into the tub. I started a wash cycle and the first water into the tub just drains out, passes through the pump and out the pump outlet hose (and onto the floor since I have the other end disconnected at the moment). This doesn't look normal to me - is the pump shot? If yes, is the pump repairable?
Thanks, Kevin
Solution #1
posted on May 22, 2009
Not Rated)
rylee_smith
Rank: Guru
Rating: 88%, 909 votes
Hi!
There are the following main reasons of leaking water---
1. Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
2. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
3. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
4. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Was this helpful?
Yes
No
Solution #2
Not Rated)
jgwhomeequip
Rank: Guru
Rating: 86%, 748 votes
Pump is not repairable and yes your pump is shot. You can replace it farely easily and cheap at repairclinic.com
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
who has the best built front load washing machine that is dependable and resonably priced.
Answer
Best quality, most reliable, least amount of repairs, front loading machine.
Answer
I have a roper type 111 top loading washing machine. It shakes extremely violent in the spin cycle... (More)
Answer
I need an Electric Door Switch for an AEG Lavamat 570 Washing Machine. Any assistance most... (More)
Answer
we have a candy washine go1482-80 it wont all ways spin out to dry the clothes and does not warm up... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14095
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
