Question about Xerox DocuColor 12 Color Copier
Fault 094-322 The machine stated fault 094-322 has occurred. I turned the machine off as instructed and now my Fiery work station is saying it is trying connect in a numbered quantity of seconds. After counting down the rip stated to turn the printer power off and on DFE-006.
I have problem code 094-322 how cant i solve ?
Posted on Sep 04, 2010
I have a docucolor 12 and x12 fiery. I am trying to calibrate from the fiery. It will printer calibration page, but it can't measure scanner. It comes up with check scanner cable connection. I have tried...
You should have a color separation guide with small gray scale from Kodak. You put the gray scale and the calibration sheet on the glass and follow the instructions from the fiery display.
Jan 02, 2011 | Xerox DocuColor 12 Color Copier
Dc 50 doesn't start
THE PROBLEM YOU ARE GETTING IS A BAD CONNECTION BETWEEN THE IOT-NVM RAM BOARD AND IOT-SYS BOARD (MAIN BOARD) , JUST UNPLUG IT AND PLUG IT BACK. IF DOES NOT WORK THE BATTERY WENT DEAD , YOU NEED TO REPROGRAM ALL 3 BOARDS NVM , IOT-SYS AND HALFTONE. I HAVE THE PWS STATION FOR REPROGRAMMING AND FIRMWARE UPDATES. THE P.C. BOARDS ARE LOCATED IN THE BACK OF THE MACHINE , JUST BELOW THE SCSII CONECTORS FOR THE FIERY OR SPLASH. HOPE THIS HELPS YOU. diesco_cxl@hotmail.com
Mar 15, 2009 | Xerox DocuColor 12 Printer
Xerox Docucolor 12 copier doesn't print when sending to FieryEX12
There is no 1 part that deals with this issue i'm afraid. The copy from the glass uses all the boards in the same path that a print uses. It definately rules out the machine fault. I would guess that the machine isn't set up properly to receive these fierys. Just make sure all connections are secure, if not try other cables.
Jan 18, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 Not Printing with another Fiery
could be a few things, the ips pwb in the machine might be faulty, which can cause these types of issues, a driver issue woth the video boards on the fiery, or other pwbs on the machine itself. You would have to run the machine for a while on another fiery to make sure no other faults occur before condemning the machine or the fiery
Jan 17, 2009 | Xerox DocuColor 12 Color Copier
Fiery xp12 is loading without end
Have you checked the paper trays are filled and ready? Also unplug for a couple of min's and see if that clears the memory as it may be trying to forfill a print request the never compleated.... Had this happen a few times....
Hope this helps.....
Nov 03, 2008 | Xerox DocuColor 12 Printer
PROBLEMS WITH FIERY AND DC 12
pls u check the fiery and dc12 printer cable. if u have another cable pls replace and chek that also. i think the problem is in only the connectres. u remove and clean all conctres and refix. maybe the problem solved.
Jul 17, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
3,066 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
