Question about Garden
Cant start trimmer
I have a hard time starting my RYOBI SS30 gas trimmer and it floods out after I get it running I have taken it apart and cleaned it but still haveing the same problem
    President:
  • 1,902 Answers
Carb float is not working correctly. Letting to much fuel in. Most likely there is a problem with needing to be cleaned I know you have taken it apart but the float still sounds like it is dirty or the needle on the float is not sealing allowing fuel to rush in
Posted on May 22, 2009
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Aug 18, 2009 | Ryobi Garden
Ryobi ss30 weedeater,my weedeater seems to be flooded.need help
Give lots of details when describing the problem. When it started, was the choke on? If the choke is on, try starting it with the choke off, or starting it with the choke on and immediately taking the choke off when it starts, but keeping your fingers on the choke so you can turn it on again if the motor begins to die. As others have described, you have a problem with the mixture screws not being set right or the carb diaphram being damaged. Your owners manual may tell you what settings to start with on the mixture screws, or you may be able to google the model number and get the manual online if you don't have one. At this point you should have taken the carb apart to look for problems and blow out the air and fuel passages. You are making progress. At least you know that it is getting spark, and getting gas. I am not familiar with that model, but many of them have three settings for the choke, fully on, half on, and completely off. If you have that type, after it starts and dies, take out the plug and dry it, then try starting it with the choke half on. You will need to clear out the excess gas while you have the plug out.
Jul 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi ss30 weedeater not starting after repair,to the primer bulb
Follow the instructions exactly. If it won't start, take out the spark plug to see if it is wet, or dry. If it is too wet, the motor may be flooded. If it is completely dry, you have to figure out why it's not getting gas. I am assuming you are pressing the bulb the recommended number of times, and that there is gasoline in the bulb, providing some resistance to your pushes with your thumb.
Jul 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Ryobi SS30 Problem, please help
Hello:
Are you Sire you Used the Correct Fuel Mix Ratio?
Remove the Muffler and Look Into the Exhaust Port.
Is the Piston Scratched and Gouged or is it Smooth like Glass?
If Smooth like Glass, then Check the Carburetor for Trash.
If Scratched and Gouged, then the Wrong Mixture was Used and the Engine is Trashed and will Require a New Piston and Jug (Cylinder) Assembly (a new unit will be cheaper than the parts to repair this unit) for the Unit to Run again.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi gas string trimmer won't run
I obviously posted this under the wrong category. I would post it properly, but I can't get back to where I was (or should be)
Sep 07, 2008 | Ryobi 15" Electric Factory Reconditioned...
Problem with gas trimmer staying started
Carburetor is out of adjustment. there are two carb adjustment screws on the side of the Carb. they require a special tool that is only $5 from your local mower repair dealer. those screws are the idle and Hi speed mixture adjustments. the carbs on Ryobi are set too lean. turn counterclockise to richen the mixture. just turn one eigth of a turn at a time. start w the hi speed.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
323 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
