Question about GE Monogram Side by Side Refrigerator
Freezer is not keeping cold and forming icicles along wall
I have a GE Monogram side-by-side with a dispenser and the freezer seems to be forming icicles along the inside left wall of the freezer. I thought it was coming from the ice machine but it seems to be starting from above it. The freezer also is not keeping items frozen. I had a person look at it and said it needs a new "de-icing kit" which he said is very expensive. Do you think this is the problem?
    Problem Solver:
  • 8 Answers
It may just be a defrost timer. Search online for information. There is plenty to be had. Check with the website of GE for a parts breakdown or your manual if you still have it for the location of the defrost timer. You can turn it manually so it goes into defrost. Does the unit seem to be running all the time and never shuts off? If so that timer could be stuck in the cool mode and the evaporator is freezing up solid so air wont flow over it to properly cool. I've had two refrigerators I've had to repair that had defrost timer problems. One stuck in the defrost cycle and wouldn't turn on to cool, the other did what you are describing. It stuck in the cool cycle and wouldn't defrost you may need to manually bypass the cooling cycle several times to allow it to completely defrost. Usually it cycles in cool from 6,8 or ten hours and only stays in defrost for over twenty minutes. That should defrost it and allow it to start cooling again. If you notice that frost has disappeared inside on the wall replace the timer.
Posted on May 23, 2009
The refrigerator side has sweat running down the side of wall next to the freezer forming water in the bottom. the temperture goes between 41% to 48%. the food spoils. what is wrong?
Without a model number, I could only guess that the automatic damper door that lets cold air in from the freezer section is broken, frozen shut, or just not operational. The refrigerator receives it's cold air from the freezer section. If the freezer is operating correctly, I would asume the damper door is not functioning. Pleazer Appliance...
Jun 06, 2014 | GE Monogram Side by Side Refrigerator
GE MONOGRAM Icemaker: ice melts and re-freezes, resulting in a large frozen piece of ice in the bin
Are you sure icicles are coming from ice bin? Remove ice bin and look above it and see if they are coming from ceiling area of freezer. Side by side monograms have had problems with drains causing water to back-up into freezer. This causes icicles from ceiling. If that,s the case you have to purchase the kit for this. This is not an easy fix and can take a couple hours, even for a pro who's done it before.
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Our GE Monogram (model #ZFSB27DAG SS) side by side is not keeping the refrigerator side cold. It seems to be working fine on the freezer but not the ref. although the ref. side does work but just barely....
First start by Cleaning Your Condenser. If your condenser is extremely clogged. Clean it and let it run over night. Then check if there is a difference in the morning. If your condenser is clean then disregard. Make sure that you have good air flow into the fresh food(refrigerator) section threw the damper control. Click here to see your damper it is number 426. Another thing to check. Open your freezer and look on the back wall to see if there is defrost frost forming. Sometimes you have to remove the back panel to verify if your coils are clear. If you have a defrost problem starting it will restrict air flow into the refrigerator section. This is the most common problem on your model. If you remove the panel and the coils are frosted and restricting air. You can take a hair dryer and defrost them to get yourself by for a few days. This would either be your defrost termination switch, defrost timer or defrost heater bad. Here is your UNIT. Click Here to contact me.
Apr 04, 2013 | GE Monogram ZISx420DR 42-inch Side by Side...
Samsung bottom drawer freezer is leaking and ice is forming along both sides of the drawer?
Is there a drain at the rear for when it defrosts that has become blocked? Defrost fully and clear drain hole
May 20, 2012 | GE Profile Arctica Stainless Steel Top...
Problem with the GE Monogram ZISS420DMSS Side by Side Refrigerator. Defrost Drain tube clogged. Icicles form in the frezer compartment. How do I fix? Thanks.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 17, 2011 | GE Monogram® ZISS420DMSS Side by Side...
Icicles forming from melting ice from ice maker
hi this might help you:
*make sure that the seal indeed still seal well enough...
*the older the fridge the more common this is
i don't really know much about this, but just check that it's cold enough inside like check if it changes when you change it from eg 4 to 7, and that the sealing is fine, and that your door is lined out good, also important that last thing offcourse, cause if it seems to shut good, but the seals arent in the right position compared to the other side (the 'fridge-walls' :p) they won't seal ofcourse...
I hope this is useful, and greets.
Oct 20, 2009 | Refrigerators
Freezer not working properly
Your heating element has failed and needs to be replaced, the heating element keeps your coils from icing up and in return when then go bad cause this problem.
May 16, 2009 | GE Monogram ZISB360DR 36'' Trimmed For...
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Cold temps
Same thing happened to us. A baffle that conducts air from the freezer to the fridge gets stuck in the "open" position and needs to be replaced. That'll fix that problem but watch for others including the water dispenser that spontaneously begins blasting water across your floor. We've dealt with this twice.
Jun 08, 2007 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram Side by Side Refrigerator Logo
737 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
