Question about GE 3.2 Cu. Ft. 6-Cycle Super Capacity Washer - White-on-White
No water is coming in, or just drips. Water is on to washer.
We've opened the house for the summer and turned on the water. Everything is working except the washing machine. When it is turned oin, almost no water comes in.
  • casselmancar May 22, 2009
    In order to put the hoses back on, do I need anything special like plumber's tape or clamps?
    President:
  • 1,136 Answers
Hi, Remove the two fill hoses and flush out the screens located inside the inlet valve. Once you get the hoses off, you can lok inside and see what is plugging them.
If there is nothing in the screens, let me know and I can assist you further.
I hope this helps.
Thanks
Vic
Posted on May 22, 2009
  • Victor
    Victor May 22, 2009
    No and be careful not to cross thread them. They cross thread easy 'cause it is plastic.
    President:
  • 1,902 Answers
Take the hoses off and there is a screen there. The screen could be blocked. Take the hose off at the washer itself not at the shut-off valve. If that doesnt work then check water pressure with the hose disconnected and turn on the water shut off. If you have pressure and the screen is not blocked then it is your water inlet valves not working properly and they need to be replaced
Bowl filling after use
Try turning off the water spigot on the wall, one at a time.
If the water stops filling then one of the inlet valves in the washer is sticking open.
If you turn off the water spigots on the wall and disconnect the hose(s) from the washer, possibly it can be cleaned or unstuck. it may need to be replaced.
If you disconnect a hose be sure the water spigot on the wall is off. If you can't turn the handle on the wall, don't force it. You can turn off your main house water valve (which turns off water to whole house). Also, put a towel under the hose connector before disconnecting so you don't have water dripping everywhere.
If anything is hard to turn, don't force it. You may need to call an experienced plumber to do the work otherwise you may damage parts and create a big water leak/mess. Here is an example of external (wall mounted supply line valves
Here is an example of an internal water inlet valve:
asher Water Inlet Valve Part Number 5220fr2006h SAME DAY SHIP GUARANTEE...
Mar 25, 2016 | Washing Machines
Slow drip from refrigerator water dispenser
Sounds like a defective water control valve W10408180
Change that out and I believe you will be fine. If you have questions please let me know, Thanks Sea Breeze
May 03, 2012 | Whirlpool Refrigerators
Icemaker overflows into holder freezing
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 07, 2009 | Refrigerators
Water drips from unit
lift the frontup2 inches should drain out back if not blocked
thumbs up
Aug 17, 2009 | Aprilaire 600 Humidifier
Water keeps dripping after machine is turned off.
turn hot water tap off if it still drips replace cold water inlet valve if it stops replace hot water valve
Aug 14, 2009 | Maytag PAV2300 Top Load Washer
The water comes out to warm even when we turn to cold
Your water pipes are in the ground and in the summer the ground gets warm. The ONLY thing to do to make the water come out of the pipes colder, is to bury them deeper, FEET deeper.
Aug 08, 2009 | Plumbing
I have a wet floorboard on front passenger side to back passenger side. It is only in summer when are is running and seems to be worse when really humid. I am pretty sure it is a condensation drain...
I believe you face this problem in summer whiles using the AC, the evaporator is fitted under the dash around passenger side, the outlet port for water may have got blocked due to dirt therefore the condensed water has nowhere to go but leak into the car.
The water outlet pipe can be visible if you open the bonnet and check it around the passenger side, once you locate it try to poke it slowly smoothly with a stiff wire and see if theres blockage and probabley by doing so water may drip out, if this way it doesnt help or if its not blocked thn the problem lies in the evaporater housing, you will have to open it , and it can be openned without distrubing the freon 134A.
Hope this helps!
Jul 09, 2009 | 2002 Jeep Liberty
I BELEIVE THAT THERE IS WATER DRIPPING FROM HOUSING FOR FILTER
I opened up the housing and saw that when I removed the water filter that the water didn't leak out . I also turned the ice macine and water dispenser off.
Feb 11, 2009 | Estate TS25AFXK Side by Side Refrigerator
Overfill protection tripping
Is there water in the drip pan? My asko developed a leaky inlet solenoid, which would fill the drip pan eventually causing a failure. If the water evaporated, the washer would run. Normally, there should be no water in the drip pan.
May 01, 2007 | Asko 24 in. D3250 Built-in Dishwasher
GE 3.2 Cu. Ft. 6-Cycle Super Capacity Washer - White-on-White Logo
76 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
