Question about Adobe Photoshop CS4 for PC
TOSHIBA SATELLITE P305D-S8818 video card opengl w/ Photoshop cs4
Hello, I have a SATELLITE P305D-S8818 with a ATI Radeon x1200 videocard. I am trying to track down information about getting the open gl to work with adobe photoshop cs4. From what I have been able to find so far is that the x1200 card supports it, but only up to version 2.0. That is what i have dug up to far. So if I am wrong please correct me.
I am running windows vista home basic but i do not think this matters in this case. Whatever.
Thanks for the help guys.
MrARCADIAN
  • 284 Answers
SOURCE: photoshop cs4
where? are you trying to download it from?, some servers are offline from time to time and are overloaded.
make sure you have adobe reader installed on your system too.
Posted on Jun 16, 2008
SOURCE: Photoshop 5.5 & 6.0 wont open or install
This just worked for me. I should say that after I installed a new DVD player with Nero essentials v7, my Adobe Photoshop 5.5 hung up without the drop down windows working. Also when I tried to shut down the computer, I would get a message that my "WMS.Idle" was not responding. I went on-line and found this posted solution:
Click Start--> Programs--> Nero (v7, v7 essentials, v8) --> Tools--> Nero Scout.
This opens Nero Scout Options window.
On the left hand column, click Indexing--> Folders.
Then at the bottom click Clear All.
Then click Apply.
At the top left hand corner of the window uncheck the box where it says Unable Nero Scout.
Then click Apply.
Then click Ok.
This solved my EMS Idle not responding problem. I then tried Adobe and it worked just find again. Looks like one solution solved two problems. If that helps anyone else, great. It worked for me!
Posted on Aug 06, 2008
pankaj_dic
  • 1250 Answers
SOURCE: Photoshop's Primary Scratch & Windows primary paging file on the same volume
this is not a hardware error actually photoshop writes temporary files, for which it uses hard drive, its alway a better to have scratch disk other then the drive where its installed, you can change this, by going to edit, preferences, then check plug ins-scratch disk, check your first scratch disk other than c, say the drive which has the maximum space, then select any drive
how do you like the solution please rate it i will appreciate your comments
Posted on Oct 28, 2008
odiebugs
  • 949 Answers
SOURCE: cannot install photoshop elements 6 in vista home edition
There is a problem with the auto-extractor.
Manually extract the files from the downloaded file using Winzip and extract to a new folder. Then run Setup.exe from that folder.
Also, make sure that your Temp folders have been cleared out.
The latest version of WinZip may be downloaded from http://www.winzip.com
Posted on Apr 09, 2009
SOURCE: Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
http://kb2.adobe.com/cps/408/kb408846.html
Posted on Aug 19, 2009
Toshiba satellite P305D-S8818 location of lid switch
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 20, 2012 | Toshiba Satellite P305D-S8818...
Toshiba Satellite P305D-S8818 PC Notebook no video
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 26, 2012 | Toshiba Satellite P305D-S8818 Notebook
Need to find sm bus and video drivers for satellite a215-s7422 using xp pro 32 bit service pack 3
your vga is ATI Technologies Inc RS690M [Radeon X1200 Series] so ati may have the driver for that your chipset is ati also
Aug 30, 2010 | Toshiba Satellite A215-S7422 Notebook
Sound not working on Toshiba Satellite P305D-S8818. Conextant HigDef SmartAudio 221 Driver installed and updated. Device manager says it's working but nothing coming out.
Toshiba Satellite P305D sound driver
Just click on the link, select your operating system first and then download the driver; http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&moid=1998634&src=EXPL
Good Luck!
Jul 21, 2010 | Toshiba Satellite P305D-S8818 Notebook
Media buttons on toshiba p305D-s8828 not working. lights on/off have reinstalled TVAP no difference think a hardware problem
1.Uninstall and reinstall TVAP so ButtonSetting.ini gets created.
2. Search for ButtonSetting.ini (will be in hidden directory) and copy into C:\Program Files\TOSHIBA\TBS
3.Open regedit
4.Navigate to HKLM\SOFTWARE\TOSHIBA\TBS
5.Change "Button Path" value data to: C:\Program Files\TOSHIBA\TBS\ButtonSetting.ini
6. REBOOT
Please let me know if you have any further questions or concerns
Thanks.
May 07, 2010 | Toshiba Satellite P305D-S8818 Notebook
Toshiba satellite p305d-s8818 drivers seem to be extinct. cant find them
You can download the drivers from the link below
http://tinyurl.com/6s6sah
click on download,button to see driver donloads.
Thanks
proton
Do rate the solution ...
Mar 11, 2009 | Toshiba Satellite P305D-S8818 Notebook
ATI Radeon X1200
As far as I am aware, you can not upgrade the graphics in a laptop unless that laptop is equipped with an MXM type slot for graphics.
Oct 26, 2008 | ATI RADEON X1900 XT Graphics Upgrade Kit...
Adobe Photoshop CS4 for PC Logo
292 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
