del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
make sure its plugged in correctly and the wall plug is plugged tightly. I had a Dell C840 when the
charger got power it had a green diode that lit up. You could test your power supply with a volt ohm
meter. if the VOM is not showing any power coming from the power supply (assuming you have the
VOM setup to match the power output of the power supply) then the power supply is probably bad.
If it works then it could be the computers connection or battery.
With the charger unplugger, look inside the plug end that you plug into the pc. On occaision, the center pin may be damaged or pushed into the plug itself. That small pin is what provides the laptop the power (wattage) info. Also if you know anyone else with Dell charger PA-10 or PA-12, try theirs. Good luck!
It happened because of the short circut - when there is short circut as a safety measure it disconnect and avoid further damage - trip off
In your case power adapter and battery are good but check the power socket of the laptop - if they are also ok then its a motherboard issue. - open it and check up for circut short.
Firstly, you should try to use correct sentence structure.
Secondly, as long as it's a pa-10 or pa-12 for the d600 you should be fine. the chargers are not specific to each laptop, rather they are more specific to the dell product family(the type of power connectors on each).
