Mt Rinnai convector 516tr will not start, have stored it away for summer got it out for this winter plugged all in after pressing start after about 20 seconds No 11 starts flashing I have exactly the same problem with my Rinnai 506 TR...........what to do then ?
  • Ruby Mardiono May 23, 2009
    My Rinnai Convector 506 TR, has been working well in the last 8 years. But, yesterday, when I turned it on, it just did not ignite (just make sound like tik...tik..tik..) and after 15 second it came up with number 11 on the display. I have unplugged for 30 minutes, then reconnect to the gas and main switch and play it round but no go. Any help please......
  • 5,807 Answers
No 11 means you have to check on the thermocouple output., it is the mts-ignition part of your heater, try also cleaning the filter as well.hope this help, thanks for using fixya!
Posted on May 23, 2009
  • 19,396 Answers
Check that the child lock is not activated first.
Prior to turn off the heater for a long timer, as suggested by the manual you always need to disconnect the gas hose. Ensure that the gas hose had been re-connected.
If gas is flowing into the convector, try first turning unit off , and then cutting power to the unit by unplugging from main for ten minutes to reset the control panel.
Check that prest temperature is not set to a setting that is higher than room actual temperature.
If the heater still does not ignite , this may be because of air in the gas supply line. The spark will continue for 15 secs.
After that you will need to press ON/OFF button OFF, then ON again.
Ensure that the room has proper ventilation.
If all that does not fix the problem, then the unit is faulty.
In that case use the fault finder table in the last part of this manual and contact Rinnai.
Posted on May 22, 2009
Rinnai convector 506tr unflued room heater won't start
Tilt switch failure is a strong possibility. They can be finicky
May 14, 2013 | Heating & Cooling
Converting rinnai 516tr from natural gas to lp
Try national energy they sell convestion kits It would need a gas fitter to do the work , you may need to a quote on this , they would be able to tell you if it is worth it ,its hard to tell with out looking at the heater .
Feb 24, 2012 | Rinnai Heating & Cooling
OUr Rinnai gas heater convector 516tr keeps on turning itself off and flashes 12 on the light panel. What does that mean and how to fix it? tks
Hi.
12 flashes means "Incomplete combustion". The code is prompted when the flame turns off because of a problem.
Check filter, check gas pressure and thermocoupling. Those are the problem that commonly trigger the code 12 error.
Here a manual.
Here Fixya thread on the problem.
Sep 06, 2010 | Heating & Cooling
Hi i have a rinni convector 516tr heater i put it on it switches off a few seconds later i think it has to do with the timers i have lost the book/
I am assuming this is a tankless heater. Are you turning the water on full throttle and is there full flow. First thing to check is the small filter screen on the inlet of the water heater. If the flow is reduced the water heat will not fire.
Sep 05, 2010 | Rinnai Heating & Cooling
Trimmer wont start from storing over winter
clean the leads with alcohol but remember not to try and start it straight away.
Apr 12, 2010 | Homelite Mighty Lite Lawn Trimmer
I have had this problem due to the heater 's combustion sensor concluding that all was not well. In my case, the heater had burned up too much of the available oxygen. I didn't notice the lack myself, so it must be very sensitive. I had shut the place up to keep the heat in and eventually it dawned on me to open a door for a minute or so every half hour or so to replenish the oxygen supply.
The situation is worst when the place is very cold as the heater will roar away trying to heat it up as quickly as possible. After I came back for a holiday in winter, I had to set the temperature down to "L" and "Economy" on plus run an electric fan heater for a day to warm the structure to the point where the gas heater could relax and not burn oxygen faster than it could heat the space.
Apr 30, 2009 | Heating & Cooling
Rinnai convector 516TR
Hi This is happening to us and I called Rinnai... they suggested that if anyone either in our apartment or an ajoining one has painted walls or varnished a floor that the convection heater picks up the smell and the only way to get rid of it is to burn it off by running the heater for several hours in a well ventalated room...
I am going to try it tomorrow.
will let you know
Jul 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
After storing away for the winter, unit has no power.
Just a wild guess but maybe it's not warm enough to activate the display?
May 27, 2008 | Haier HWR06XC5 Wall/Window Air Conditioner
Heating & Cooling Logo
245 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
