Question about Polaroid FLM-323B Television
Flm323b power supply
Ok first off I have spent hours tracing and drawing the schematic for this power supply. It is the 200-PO0-MLT666A-AH.
Photo.
http://cabaret-karaoke.com/pol/polar1.jpg
Schematic http://cabaret-karaoke.com/pol/Root_1.PDF
It was blowing fuses. Q2 and Z1 were shorted. Replaced them and got a red light. Hit the switch and got a blue light for about 5 -10 seconds Then the fuse blew again. This was with the inverter board plugged in. Now the the fet and zener are shorted again.
Nothing on the inverter board shows a short. But I wish Id a tried it with the inverter unplugged. Ideas????
  • red neck Oct 14, 2011
    Links are dead do you still have them
Replace Q2 by 18N50, Q8 and Q9 by STP6NK60 and Z2 and Z4 by !n4739. I have the same problem and fix it.
Posted on Sep 30, 2010
Can I get wiring schematic for mitac X-200/12v power supply
Hi
If you copy the link below and paste it into the address bar of your browser, it will take you to a web page towards the bottom of which is a link showing "To download this file, click here". Upon doing so a pdf diagram is downloaded. This is a schematic which looks like the one you want.
http://www.eserviceinfo.com/download.php?fileid=39548
Cheers
Aug 10, 2014 | Mitac X-200/12v 200w Switching Power...
Audiovox schematics
If the player has a rechargeable battery older than 2 years, it is probably going to need to be replaced. Look at the volts-Ampere-hours rating, and replace with same volts more ampere-hours AH rating.
Aug 01, 2014 | Audiovox D1998 Player
I need trace schematic or diagram for power supply board PLCD300PS07
I have the same PS - did you ever get a diagram ? I'm after one too....resistor R100 completely blown so I can't read its value but its either 900Ohm or 100Ohm ?
We might be able to compare symptoms....
Feb 26, 2013 | Televison & Video
TV went out and there was smoke....
Contact the nearest authorized service center for Poloroid. Your TV need initialization.
Oct 05, 2012 | Polaroid FLM-3234B Power Supply Board...
Looking for a Service Manual for Sansui AU 9500 Amp. more detailed than the Operating Instructions and Service Manual available on the Web.
I hope this schematic diagram will help you find the problem of this amp.
Try to give signal to the aux input and trace and find where the signal disappears.
When you get to the site using the link it is possible that you have to wait a little bit to be able to download.
After waiting you should see a button as "Get Manual" and simply click on it and save the file.
Thanks.
gylacz
Jan 01, 2012 | Audio Players & Recorders
SCHEMATIC DIAGRAM FOR ATX250-3505
While this link will show you a schematic for a 200 Watt ATX, the one you seek should be similar.
http://www.pavouk.comp.cz/hw/en_atxps.html
Dec 29, 2011 | Astec 250W Power Supply w / External Fan...
I buy a new power inverter ERP 2300 12v/220Volts
What does the inverter over 600 Watt.
By what type of battery is the inverter supplied? How many Ah? What is its state?
In order to achieve 1000 Watt for 1 hour you need a fully charged 12 V / 100 Ah lead-acid battery.
If your battery is less then 100 Ah and is not very well charged or old (bad) you may not have over 600 W, but not bacause of the inverter, but the battery.
If your inverter stops due to low input voltage (you can see it in the digital display during operation).
If you want to check the real output power of the inverter you should connect it to a big (more than 200 Ah) well charged battery.
Jul 22, 2010 | PowerBright Power Bright ERP2300-12...
Toshiba
do you get a flashing led if so how many times?
this is a post from someone else:
Thought I would report my finding with this set. Maybe someone else is experiencing the same problem.
The set would turn on with no picture. No high voltage - no raster. By turning up the volume, you can hear some noise in the speakers. This set has many fuses and they all checked out ok.
I located some schematics on the net for the previous generation set - 40H80/56H80. I could not find any site with the 50H82 schematics without paying. The 40H80 seemed to match the 50H82 fairly closely. I checked the horizontal output transistor with a scope and found no signal. I traced the signal back to a board on the signal schematic called the DPC module. No HOT signal was being generated by this module. Per the schematic, I checked the voltage supply pins at this module and found everything ok except pin 6 which is supposed to be +12V. I traced this back to the power supply connector and found voltage (pin3 of 8 on BB30). Since I got the set for free and I was feeling risky, I shorted the +12V at the connector to pin 6 on the DPC. I got a small spark and the set shutoff, but I could hear static which indicated that the HOT briefly same on. I shorted out the connection again and turned the set on. This time is powered up and came back to life. I've run the set for a couple days so far and it appears to be working great.
I may have gotten very lucky, or I may be shorting out something that is not supposed to be shorted. I would really appreciate it if someone who has the real 50H82 schematic could check the connection between DPC pin 6 and the power supply connector BB30. If this is a real connection, I have to assume that the trace burned out somewhere. It vias up and down all over the place and is very hard to follow.
Dec 11, 2007 | Toshiba 55H70 55" Rear Projection...
Polaroid FLM-323B Television Logo
914 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
