Question about Karcher K2.26 Electric Power Washer
Karcher electric power washer
The trigger appears to be catching. I was noticing that I was having to push it down harder than usual this a.m. PW worked for about 30 minutes this a.m. However, after i released the trigger halfway into the job and then tried to pull the trigger again, it would not completely engaged (and hence the pump and spray was not coming out). I kept pushing and the trigger finally pushed down completely, but then refused to engage after about 6 or seven more rounds with this.
I gave up, but then I came back after about an hour or so, and it worked for as long as I held the trigger down. Once i released the trigger, it would not engage again. The safety feature is turned off.
  • 92 Answers
Dear, cb_scherer,
I can only give you some hints because I do not know the type and model of gun. First if your gun is put together with rivets and not screws, this could not be serviced. In this case you have to buy a new one. Now if you have screws, normaly Torx(T15) or sometimes Philips....you can open the gun to have a look inside. Some guns have an adjustment for correcting the travel of the trigger. This is a simple alen screw. Now if damage has been caused to the pin that is pushed by the trigger, then also a new gun is a must. In my opinion I rarely service guns. Infact the only guns that are serviceable ,..are of industrial machines. As I said, I do not know what type of machine you have and so I do not know the type of gun you have.
My general advice, is to buy a new gun. A gun is not that expensive. And working with a faulty gun not only in time will damage the machine, but it is also not safe!!
Regards,
Fulltech.
Posted on May 30, 2009
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
Karcher K4.97M electric waterblaster cycling
It sounds to me like the unloader valve is bypassing internally.
Nov 16, 2009 | Karcher K2.26 Electric Power Washer
Vacuum lock when releasing trigger. water will
It sounds like the valve in your trigger gun is sticking. Depending
on the model it can be rebuilt or repaired
Sep 08, 2009 | Karcher Garden
I have a Karcher 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR that I have used once last summer. I have stored the PW in my basement with no fuel in the gas tank. The PW was never exposed to freezing...
Hi I have a similar pressure washer from Kartcher and the same scenario as yours I have owned it for about 2 years and noticed that it was getting harder and harder to start with each time I use it which is months. If your pw has a honda engine on it the likely culprit may be the carbuerator. The main and pilot jets may get clogged up with gunk from dired up gasoline. To see if you have a fuel problem spray a shot of starter fluid into the carberator with the choke open, then close it and try to start. If it runs for about a second and dies, then the carbuerator is at fault and you are not getting fuel into your motor and all you're doing is working out your arm.
Jul 05, 2009 | Karcher G 2600 VH Gas Pressure Washer
Karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Troy
Jul 05, 2009 | Karcher K2.26 Electric Power Washer
Cycles, never builds up full pressure when trigger pulled
If you are sure it is not a bad o-ring and you have re-assembled it correctly then try this.
Visit here:
http://www.rjbowers.com/parts_manuals/partslist_1190343804.pdf
Part # 8 in the pump, karcher # 9.001-187.0 includes a small bullet shaped valve. It could be leaking. It can be carefully disassembled and cleaned.
Jun 13, 2009 | Karcher K2.26 Electric Power Washer
Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Jun 04, 2009 | Karcher PSI Electric Pressure Washer
Karcher K3.91 compressor run for a few seconds every 10-15 second
They have a problem. I removed both valves and lubed with lithium grease as I was told. Unit is now working for how long who knowes.
May 18, 2009 | Karcher PSI Electric Pressure Washer
Karcher K2.26 Electric Power Washer Logo
166 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
