Question about Frigidaire FSC23R5SBK Air Conditioner
Outside ac fan shuts off but makes noise, will restart ok for awhile then do it again
Outside unit runs ok sometimes. sometimes it makes a noise & the fan does not run. when this happens i turn off unit for a bit, then it works again.
    Guru:
  • 1,524 Answers
Oil the motor with 3 in 1 oil for motors. (Blue and White can)
Posted on May 22, 2009
How do I get my AC running again? Ruud UBHC AC unit isn't running. Started yesterday or today.
Sounds like there is no control voltage. Either the transformer to reduce the voltage from 110 volts to 24 volts is not producing the 24 volts needed for control voltage, or most furnaces have a small 3 or 5 amp fuse mounted on the main control circuit board that may be blown. Other "outside circumstances" may involve a break in the thermostat wire...more than likely the red wire if you are getting nothing to work. I have seen evidence of "critters" that have chewed through the low voltage thermostat wiring that would keep the thermostat from controlling anything. To check this, go to the furnace and jumper the red & green wire to get the fan running just to isolate if it is a thermostat wiring severred. Good Luck.
Dec 11, 2014 | Ruud UBHC Air Conditioner
Outdoor fan will stop running and compressor overheats and shuts off. it wont come back on til u reset it at the thermostat. the outdoor unit has a new compressor and fan motor.
I realize the outdoor unit has a new compressor and fan motor - therefore - both those components should be ok - however - the fan motor 'should not' be going off - and the fact that it is going off is what is causing your compressor to overheat and shut off.
The reason the fan motor is going off is - it is bad (breaking down electrically) and is going off on the internal overload. If this is the case (a) the motor needs to be replaced or (b) it's possible that the fan capacitor needs replacing; but fan capacitors generally do not cause much problem, and when they do go bad they usually develop an obvious (to the eyes) bulge. If the capacitor has a bulge in it - I would surely change it out -and probably would (as a shot in the dark) anyway - since they are relatively cheap ($10-$15).
In your complaint you say that "the outdoor fan will stop running and compressor overheats and shuts off." If it happens 'exactly' that way then I'm betting your problem will be that the fan motor is defective as mentioned above, with an outside chance of the capacitor being defective, in which case if it isn't the capacitor - you will need a new fan motor. Note: outside fan motors are notorious for being fickle and it would not surprise me in the least to find a fairly new outside motor that is defective. I would check and see if you had any warranty on it.
All that being said - it is also possible that your outside unit has a 'high pressure cut-out switch,' although most units don't have them anymore, these days. However, if you have such a switch - it is possible (very likely) that it is shutting off the AC. Note: a high pressure cut-out switch will 'shut the entire outside unit off,' not just the fan motor. If that is what is happening then there's a good chance you have such a switch.
If it is happening that way, (the entire outside unit stops) then I would try 'washing the outside coil' really, really good and see if it will run ok afterwards.
Note: outside coils are sometimes difficult to get clean - sometimes requiring you to disassemble to some degree in order to make sure you get them clean.
Always, Always turn all power (including inside thermostat) OFF when washing the outside coil.
Jun 07, 2011 | Heating & Cooling
Turned on AC was running fine. 30 minutes later began to hear a strange noise. Opened AC/Furnance closet & heard a sound best described as air letting out of a tire. It seemed to be coming from...
Hi!!
This means that the condenser fan motor (outside unit) failed, this caused to build hi pressure and either activated a safety valve to release the extra pressure or blew a line and R22 Refrigerant escaped from system.
The fix is to replace motor fan and capacitor find the leak and refill system with R22 Refrigerant Gas. It is safe to turn on the Fan Only mode on the Thermostat until a HVAC Tech arrives.
To perform this job parts and labor included will cost: about $300 -.$400. Look on the Yellow Pages for a Tech in your neighborhood.
Good Luck!! Don't forget to Rate this post!!
Aug 13, 2010 | Goodman CKL42AR42 Air Conditioner
My furnace fan still blows but the ac shuts off i went and pressed the red pressure button on the bottom of the unit it will run for awhile but will shut off again and again wondering if the unit is junk...
turn off the system at the t-stat and at the high voltage disconnect to the outside unit or the curcit breaker at the panel WARNING FAILUR TO FOLOW THIS STEP CAN CAUSE SERIOUS INJURY remove the screws from the top and side that has the pressure switch in it and remove the top with the fan. run water from the inside of the coil to flush out all the dirt and mostlikely cottonwood fly that has caked itself on the coil. reassmble the unit and and is should run just fine. if it don't call out a tech to check operating pressuers. the high head pressure may have caused a leak
Jun 26, 2010 | Heating & Cooling
Carrier Compressor Issues?
When you shut it off and back on it slugged the compressor if you turn it off and back on before the pressures equalize between the high and low sides it will slug the compressor and it will not run should let sit for five minutes or so before restarting. The humming is either the compressor making noise usually common for the compressor to make some noise or the fan motor bearings are getting bad on the outside unit. If the unit works normal probably not much you can do till it breaks if it is the compressor it is more economical to replace the whole unit if it is just the fan motor it is worth changing. You could take an amp draw on the fan motor and the compressor to see if the are within the limits on the name plate of the outside unit.
Jan 25, 2010 | Heating & Cooling
Horrible awful noise coming from carrier heat a/c wall unit!
I watched your video on youtube. Sounds like a seized compressor. Do you know if it is reverse cycle or electric heat?
Jan 18, 2010 | Carrier 52PQ307 Wall/Window Air...
Fan is making clunking sound like it is hitting something.
Yes, it certainly can be, especially in high humidity. Run AC just about 1/4 way from max and crack the windows. The ac will work better and ice up less.
Jul 29, 2009 | Fedders U Chassis A7U12W2A Air Conditioner
AC fan not working
turn it off call repairman
Jul 11, 2009 | Heating & Cooling
Why is my air handler fan motor tripping the 20
sounds like fan motor is going bad - replace
Jun 15, 2009 | Heating & Cooling
Heating & Cooling Logo
242 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
