Question about Sony Ericsson K800i Cellular Phone
Disc2phone Erases the Intro to songs
The Disc2phone software erases the first 30 seconds off the start of all songs I try to change the Bitrate!!!! Why!?! Is there any other software I can use
    President:
  • 2,004 Answers
Why cant you rip music from cds to Windows media player in mp3 format and transfer to your phone?
That;s a very good way.
Rate this.
Posted on May 22, 2009
Nextar MP3 player won't work
Seems like you are trying to play very high quality songs or their format is incorrect.
Format the mp3 player's internal memory in FAT file system. (Format is same as erasing the entire memory contents). Before copying your songs encode them in the mp3 format with bitrate 128kbps max. Try 64 kbps if it still does not work. Remember to copy your songs to the memory directly or to its predefined folders. Try not to keep folders to just one.
You can try these free software samples to encode your songs (if you already do not have one):
FreeMP3 RIP
FreeRIP
Please note that there are numerous other software for encoding tasks. I am providing the above links for reference only and have chosen them randomly. I am in no way affiliated with their developers and take no responsibility for their actions.
Sep 09, 2009 | Singer Tiny Tailor TT700
SONG ONLY PLAYS FOR 30-40 SECONDS
pure,
Most probably you accidentally switch the play mode to " INTRO" check your display if it does indicate Letter " I" in it. if does any music you play will be in "INTRO" mode. IF you still have the manual for your player check the 'PLAY MODE" setting. From this setting you can choose play mode from "FOLDER" "NORMAL" "INTRO""REPEAT 1" REPEAT ALL" to play in continuously select "NORMAL" mode.
I'm not sure if your player do have the same procedure in changing play mode . But try this , while on play mode . Press menu and a dialogue box will appear scroll and select "NORMAL"
cheers,
mark
Feb 04, 2009 | GPX MW3836 MP3 Player
I try to listen to one particular song, but Sansaclip 2gb freezes
Epsilon - delete that one song and see if the other songs play fine
unschool:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa Clip MP3 Player
Only plays ten seconds of songs
I HAD A VISUAL LAND MP3 PLAYER. ONLY PLAYED FIRST 10 SECONDS OF SONG. IT IS SET TO INTRO. WHILE THE SONG IS PLAYING PUSH THE BUTTONS AND YOU WILL SEE THE OPTIONS COME UP. SONG HAS TO BE PLAYING. CHANGE FROM INTRO.
May 31, 2008 | Centon Electronics MP4-001 MP3 Player
Sansa having problem with sync
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 26, 2008 | SanDisk Sansa e260 MP3 Player
Sandisk keeps skipping/freezing songs!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
or
-Tha Mp3 Doctor
Apr 13, 2008 | SanDisk Sansa E280 MP3 Player
Coppying problems
Note: this method erases all songs - starts you over:
Go ahead and do this, in case the DB is corrupted:
-Tha Mp3 Doctor
Apr 08, 2008 | SanDisk Sansa e250 MP3 Player
Deleted songlist! e260 MP3
Try pressing f5 for refresh in Windows Media Player first (with your Sansa player connect)
or
-Tha Mp3 Doctor
Apr 07, 2008 | SanDisk Sansa e260 MP3 Player
MP3 player disfunctional
-Tha Mp3 Doctor
Jan 08, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
My sansa keeps rewinding the songs to the beginning 5 times every song starts
Make sure the songs are not streaming versions
if not:
or
-Tha Mp3 Doctor
Dec 12, 2007 | SanDisk Sansa e260 MP3 Player
Sony Ericsson K800i Cellular Phone Logo
47 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
