I have a c120 classic and i upgraded my navionics gold chart using navionics update. aafter a successful download, i am trying to view the sonarcharts on the display. i was able t see it once but i really don't know how to get it back again. Also, trying to scroll around the area, the MFD was very slow in redrawing the area. when i take thenaviojnics card out, the redraw rate goes back to normal..
its probably out of guarantee and that is a special card what goes in there, i'm afraid you need to send it in for repair and pay the costs yourself, i had a similar problem
Sadly, the mic and cord for the Ray54 have been discontinued by the manufacturer. I guess if you plan to buy a Raymarine VHF, your best bet would be to buy a spare radio for parts. Unbelievable.
Here's the link to that conversation from Raymarine support.
I realize this question is old, but the information could be helpful to someone else.
-Steve Raymarine 54 Mic Chord
50/200 combination will work fine but 170/200 may be a little close in frequency and give you some trouble. "May be OK" doesn't leave me with a lot of confidence.
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage).
good luck
847-746-0100
John Barry
If it is an RS 120 or an RS112 antenna you do not need to change it.These are both active antennas in other words they do all the gps computing in the unit itself. You need to look at the wire from the antenna. If it is a coax cable(2 wire) it will not work.If it is 3 or 4 wires it will work. If 3 wire (red ,silver yellow) just hook up color for color.If 4 wire you are going to have to figure out the wiring for it from the units wiring diagram.That could be a big enough pain that you might be inclined to change to the new antenna. If you wire the new RS125 antenna you must wire it to the seatalk buss. The seatalk wires are Red Silver and Yellow.The wire from the RS125 are red yellow silver green and brown.Wire as follow to your sea talk cable.Yellow to Yellow, red to red , silver to silver, green to red, brown to silver.
Hope this helps.
