Question about Ricoh Office Equipment & Supplies
Ricoh GX5050N banding
I have a Ricoh GX5050N. When using photo paper, it leaves white lines or bands across the page. It is not usually consistent. I am not sure if this is a printer or paper problem.
  • Anonymous May 11, 2010
    Only on photo paper? are you using the bypass tray (you should be), and do you have the paper type set to an appropriate type? For example "Thick"?
  • 16 Answers
It can be due to the fusing temperature not being right.try to change the paper type to a heavier paper type to increase the fusing temp.
Posted on Jun 06, 2009
Printer creates horizontal lines across paper that are either blank (no ink) or skipping/sliding looking blurring and distorting the text in that spot. This has been going on for a month. Changing...
The print-head is like a paint-brush -- brush sideways across a white-coloured wall, and you should get a wide "band" of paint. If only half of the paint-brush has paint on it, then only half of that "band" on the wall will get painted, leaving a horizontal strip of white showing through.
So, launch the Canon software that is installed on your computer, and run a few "print-head-cleaning" cycles, to unclog those ink-jets that are _NOT_ shooting the ink onto the paper.
May 20, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Colour printing comes out in lines across the whole page
Is the nozzle is perfect? i dont think so. But, if you print with best/photo mode is ok.
Jun 01, 2009 | Canon i850 InkJet Photo Printer
Xerox XC1020 White Bands running across copied page 4" apart
The metering blades in those cartridges go bad and do not allow the ink to get to the page. Look at the front of the toner cartridge, is should be a solid consistent black all the way across, if its streaky, not consistent all the way across replace the toner.
The other problem could be a dirty laser. If replacing the toner doesnt work let me know, I will tell you how to remove and clean the laser.
Jan 16, 2009 | Xerox CopyCentre C20 Black and White...
White band on photo glossy output
Open printer, remove drum, clean laser lens with soft dry cloth, reinstall drum.
Manufacturer's Instructions
website: printer.konicaminolta.com
white vertical line (s) / how to clean the laser lens
Cleaning the printer. (5 pages)
Worked for me
Watemusic
Nov 13, 2007 | Minolta magicolor 2400W Laser Printer
White line across printed page
Hi Alms, Is there any chance you can post a scan of one of your faulty pages. This would help to assess the fault. If you print several pages, does the image move further and further down the page with each copy? Is the white band repeated down the page? If so measure the distance between each band - this will help identify the faulty component.
May 21, 2007 | Minolta magicolor 2200 DeskLaser Printer
Horizontal White Banding
Most likely cause is that a roller has degraded during storeage. Measure the distance from the centre of the first band to the second and from the center of the second band to the third. If this dimesion is fairly constant you can work out exactly which roller is causing the problem. The most likely culprit will be the Photo Conductor Unit. This will give a large dimension - (approx the 29cm??) A service manual should give you the dimensions (circumferences) of the rollers within the machine. If you have a spare pcu around, put it in and see if it makes ANY difference.
May 13, 2007 | Konica Minolta magicolor 2300DL Laser...
White bands across printouts
Either one of the print heads are bad or a cartridge. This is what causes that problem. I know it is a hassle but I would take it back. If try and fix it you could void the warranty.
Mar 16, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
122 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
