Question about LG LW5200ER Air Conditioner
Heating problem hello! My air conditioner stopped to heat. (there is a around 8 degrees C, outside and 16 degrees inside). It worked just fine, and now, when I switched to heating mode, there was nothing. the defrost LED ond the inside unit is switched on, but air is not comming from the unit. Cooling mode works fine. If you could please help me finding the solution for my problem. Thanks in advance. RAdan
  • Anonymous Mar 27, 2014
    inside unit light flashing 6 times on the cooling light and 7 times on heating light
  • LG Master
  • 4,655 Answers
The LG>LW5200ER AC is not listed as a heat providing unit. Click on link and this will give you the spec's
http://www.epinions.com/pr-LG_LW5200ER_Air_Conditioner
Hope this helps.
Posted on Oct 21, 2007
Somethimes t gives a tikkend sound by a half hour and then it stops and you onely hear a constant quit noise. greeting Mary
Are you trying to heat with your air conditioner?-- here are a few points to keep in mind:
Remember, for an air conditioner to PUT OUT HEAT-- (as HEAT PUMP) -- there has to be some HEAT outdoors, to make the process work...
So-- ask yourself-- How cold is it outside?
How cold was it outside, the last time that my AC worked good as a heat pump?
Possibly the coil outside is all frosted up?--
Shutting it off, and letting the outside coil defrost might help-- but-- the basic law of physics still stands: To get heat inside-- there has to be some heat outside! (Likely your unit won't give you much heat inside, when it is below 50 -- or for sure-- below 40 degrees outside!)
Give us a few temperature readings- inside and out, and then gives us clues as to what is running, and what is not-- maybe we can trouble shoot deeper. Is the compressor running?-- does it sound like it is actually working-- or just running-- sort of like 'running but not really WORKING'?
Let us know--
Mack B
Jan 18, 2011 | Heating & Cooling
Will not put out heat
Let us know--
Mack B
Jan 18, 2011 | Samsung Heating & Cooling
I have a Lennex heat pump unit which was installed in 2008. Our area (Savannah, GA) has experienced some abnormal cold temps lately. Yesterday, I noticed the outside of the unit had frost on the unit. ...
Heat pumps are the same as an A/C unit only it works in reverse. Instead of blowing cold air inside and hot air outside it blows hot air inside and cold air outside. The heat being blown inside is extracted form the cold air outside. Its called Latent heat Latin for hidden. Believe it or not even though its 20 degrees outside there is still heat in the air. Example if you want to drop the temperature of a freezer from 20 to 10 degrees you have to remove heat .I know your getting unusal weather and that is the problem. Heat pumps can only work no lower then around 20 degrees outside.Heat pumps are never used above the freeze line. With your unusal temperatures thats basically where you are now. Ride it out. When your temps rise a little your be fine. Im in Chicago.
Jan 15, 2011 | Heating & Cooling
Problem for Goodman CKL60AR60 Air Conditioner, what should be the right pressure on low /high side
Hello my name is Heath it will be my pleasure to assist you. If you are talking about r-22 with an outside temperature of 75-80 degress farenheit it should be running between 62-68 on the low side and 200-225 on the high side but there are varibles to take into account like the air flow across the inside coil or a dirty evaporater just things to take into account these pressures are approximate if there are close it should be fine.
Aug 02, 2010 | Goodman CKL60AR60 Air Conditioner
Every time my heat pump turns on, the blue auxilliary light comes on, and it only blows icy air. I do not want to use that much power, so I turn it back down a few degrees. Now, it is 50 degrees in the...
A heat pump starts losing efficiency below 30F or so. The aux. heat helps the heat pump keep up with heat demand. The Aux heat can be electric heat strips or another type of heat. Check to make sure you have power to whatever type of aux heat you have (breaker not tripped, no overloads tripped). If it is electric heat check the heat strips to make sure they haven't burnt in to. Hope this helps.
Jan 10, 2010 | Amana PTH123B25AJ Heat Pump Air...
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
Hello, I have a 1.5 ton rudd ac/heat pump
Your outside unit is not defrosting. You need to call a service tech to check it out. Defrost board sensor or low on gas. Also you amy have an outside tstat that is not working correctly. Rus
Dec 06, 2009 | Ruud UAMB042 Air Conditioner
Heating problem
Hi Radan, Did you get this problem solved? We have an Electrolux Kelvinator Split System and ours is doing exactly the same thing. I am struggling to find a solulution. Would be great if you can offer any advice.
Thanks Nicolle
May 03, 2008 | Heating & Cooling
Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Nov 28, 2007 | GE Zoneline AZ55H09D Air Conditioner
LG LW5200ER Air Conditioner Logo
106 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Steve F
John Tripp
John Tripp
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
