Question about 2wire (1000-000057-000) Modem
Internet will stop working when laptop goes on standby
I have a desktop pc and a laptop hooked up to a 2wire modem. often i will disable the wifi on the laptop and connect an ethernet cord straight to my laptop. problems have occured when i either disconnect the ethernet cable from the laptop or put the laptop in standby mode with the ethernet cable still connected to the laptop. when this happens it causes the modem to malfunction disconnecting from the internet. I am not able to connect through the desktop laptop nor iphone at this time. the modem then begins to cycle through the connection process. all light become a solid green and the internet works for about 3 seconds and a red flashing light comes back on. I have tried everyhting i can think of from restarting both computers to unplugging them and restarting the modem. the modem will not work for about a day and randomly start working perfectly again for no reason. this has happened on and off for about a week
  • 3,866 Answers
Www.2wire.com I would be calling these folk in a heartbeat this should not happen and the fact is this is a malfuction with the modem myself. I have 2 of these modems without this issue.
Posted on May 22, 2009
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
My laptop asks for a Device Ownership Password and none of the numbers/letters on the 2wire device works....how do i find the device ownership password so that i can connect wireless with my laptop?
Device ownership code is part of a stupid contraption called WiFi Protected Setup (WPS), which was meant to simplify connection to wireless access points, but doesn't simplify anything in my opinion...
If the modem has been set up by your provider, then they should supply you with that number. It may be printed on a sticker on the modem itself.
Alternatively you may try finding in your laptop WiFi settings an option to disable this WPS functionality and connect in a "normal" way. It's hard to give a solid recipe, as there are lots of different WiFi software packages out there - every manufacturer seems to have an ambition to come up with their own, whereas Windows since XP Service Pack 2 onwards can use WiFi natively, without any 3rd party add-ons.
Jul 22, 2011 | 2wire (1000-000057-000) Modem
I have a 2wire 397 modem router from att in line ,i want to add another 2wire modem router in line to a different room to hook up a samsung 3d blu ray to go on the internet
you cannot have 2 modem routers on the same line, if your current modem router has wifi, you might consider using a wifi repeater that will pick up the signal elsewhere and give you added lan ports. alternatively, you could just run a lan lead to where your samsung is and use a 5 port lan switch.
Apr 26, 2011 | 2wire (2701HG-B) Wireless Router
I have a 2wire 1000SW router/modem connected by an ethernet cable to a Hewlett Packard media center PC running Windows Vista. The internet Wifi connectivity problem arose after I visited a best Western...
If you check your router you will find a reset button or a little hole in back insert pin in hole and press for 10 seconds your Moden should have reset now you will have to put in your login and password to access modem
Feb 28, 2017 | 2wire Computers & Internet
Cannot hook to internet
This may not be a solution, but I recently was attacked by a free software website, that disabled my internet connection settings.
In Internet Explorer properties, or the menu item Tools / Options, there is a tab called "Connections" this is where your computer's internet connection decisions are made.
One option, in the LAN Settings button, is to "Automatically Detect Settings". My attacker somehow repeatedly disabled this option and I had to enable this each time I restarted my computer.
Something to try.
Jan 16, 2010 | Computers & Internet
Why does my 2wire modem often show disconnection
Wireless network requires the modem to be placed at such a place so that there are not too many things come in its way. Eventhough the modem works for few time , putting the modem at top place not covered by so many things would make the modem works better and not to stop often.
Sep 17, 2009 | Computers & Internet
I have a bigpond supplied 2wire wireless internet modem (2701HGV-W) which works seemlessly with my laptop running XP-sp2 for internet and email. Recently I purchased a Brother MFC 6890-CDW which offers...
Check if it's recognised on the local area network etc,make sure driver is installed and you may need to reset all pc,router etc to get connection.Now remember you need a router for this to work,with only a modem it will not function.You also need to restart all instruments etc before it's picked up by the router and the network..Google a bit and it will solve this.Make sure it uses wifi and not bluetooth as then it will need the right bluetooth connection to your pc..
Jul 27, 2009 | 2wire (1000-000057-000) Modem
Problem getting to internet through 2wire 2701hg-b router
how can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Apr 22, 2009 | 2wire Computers & Internet
My internet won't work on my new laptop.
First turn off you laptop. Second, go to your comcast cable modem unplug it from the wall and wait about 3mins. Now plug the comcast modem back it and wait for all the lights to come back (will take about 2-3mins). Now plug the yellow ethernet cable into your laptop if its not already and turn your laptop on. You should now have internet.
Also if you using a Comcast Surf Board modem be mindful of the standby button on top of the modem. You can tell your in standby mode if the standby light (bottom light) is amber. If it is press the standby button once to get out of standby mode.
hope that helps
May 12, 2008 | Computers & Internet
2wire sbc wireless modem connection
      Dylan,      I don't know who your ISP provider is, but I am using BT and had to change to a Belkin modem so that I could connect Archos 605 wifi and Palmone.  Had the same problems as you have, which have disappeared on installation of Belkin modem,
                             Samcalm
Jan 05, 2008 | Archos 605 Digital Media Player
2wire (1000-000057-000) Modem Logo
388 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
