Question about Dishwashers
Dishwasher is not getting water in. I have disconnected the Water level Switch assembly. How to test one on stand alone basis, what voltage has to be applied to see if it is opening (it's normally in
My Bosch SHU3032UC12 dishwasher is not getting water in. I have disconnected the Water level Switch assembly. How to test one on stand alone basis, what voltage has to be applied to see if it is opening (it's normally in Closed position) ? Thanks in advance, Chris
    President:
  • 1,136 Answers
Hi, The inlet valve needs 120V to open
Hope this helps.
Vic
Posted on May 22, 2009
Dishwasher is on and connected to water, but no water coming in.
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 27, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Hello my tricity bendix dishwasher won't take in water, it will pump it out and when I turned water off at the mains and disconnected the water pipe and put it in a bucket turned mains back on the...
Hi
Daniel
Aug 11, 2011 | Tricity Bendix 24 in. DH102 Free-standing...
Dishwsher doesn't get disher clean
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 07, 2011 | Hoover 24 in. DT999 Free-Standing...
Unit won't fill with water
Hi
Daniel
Aug 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
My dishwasher draining but does not take water in
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back if you need more information.
Daniel
Jun 07, 2011 | Danby DDW1805W Designer Series...
Dishwasher not filling with water. Humming noise.
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Jan 08, 2011 | Bosch 24 in. SGS43C12 Classixx...
Washer drains at it fills up, so water level never gets to where it needs to be. This is in all cycles. Machine never get to a point where it starts running.
Your drain hose needs to have the "curved" part above the level of the basket top. Otherwise, water will continually run out (usually onto the floor).
Some models have a stand alone water pump that is turned on to drain the washer. The timer (during drain, spin, etc cycles) turns this pump on and off. If your hose is inserted into the stand pipe as it should be, then the water pump being turned on is likely the problem.
Since you aren't mentioning that water is all over your floor, I think that a loose / torn hose can be ruled out as well. You need another timer switch assembly.
Jun 28, 2010 | Maytag HAV2557 Top Load Washer
DISHWASHER IS ONLY FILLING WITH A SMALL AMOUNT OF WATER
The water level detector pipe could be obstructed / blocked. This thin plastic pipe is at the bottom of the washer and as it fills to the correct level of water the pressure in the pipe activates a water level switch in the washer. Sometimes the air pressure pipe becomes blocked / obstructed or the contacts of the pressure switch become burnt. You can disconnect the pipe and blow through it and the pressure switch is normally factory set and does not need adjusting. Replace it if necessary.
Mar 25, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Tempstar Door model keeps overfilling
The sensor is a plastic pipe (vacume) / and a ajustable switch. The rise in water causes the air pressure in the pipe to increase and at the set level this stops the water inlet valve. You could disconnect the pipe and blow into it slowly and should hear the switch click. Most faults are the plastic sensor pipe blocked / obstructed and or the switch terminals (inside switch) burnt. This means that the switch must be replaced and should be set for the correct water inlet.
Jan 21, 2010 | Jackson 25 in. TempStar HH Free-standing...
Dishwasher
Check to see how fast water is entering the dishwasher.
They work on a timed basis with a float switch being a safety.
You may want to check how the water gets into the dishwasher and  then see if there is plugging somewhere.
Feb 16, 2008 | Indesit 24 in. D61 Free-standing...
Dishwashers Logo
175 people viewed this question
Top Dishwashers Experts
Owen Barnes
