Question about Zanussi ZWF1430W Front Load Washer
Washer continures to fill up with water to the point of over flowing and won't start a cycle
My washing machine will not stop filling with water. It over flowed. It won't start a cycle. Please hep me.
  • 1 more comment
  • frances jones May 23, 2009
    I will try and locate this wire. My washer is a top load. Will your possible solution apply to the same top load washer?
    I will let you know the out come. Thank you very much for your help.
  • frances jones May 24, 2009
    Hi, I have opened the back of the washer. I see the wire plug conections in place. There was one wire with a little round circle on it which I really can't see where it could go. Please can you tell me what the valve looks like . I really appriciate your help as I can't aford a repair man.
    Thank you
  • frances jones Jun 22, 2009
    Well I was able to get a new valve and put it in today, but the water still keeps filling and won't start the cycle. It will spin, it just won't agitate. Any other suggestions. I just don't know what to do next. Please help me.
  • 351 Answers
Is most probably the inlet valve at the rear of the machine where the inlet hose connects too.
May have to remove the rear panel to gain access to valve, it may just be a wire has come off
Hope this helps
Posted on May 23, 2009
  • Harry Goodwin
    Harry Goodwin May 24, 2009
    It should apply to most washing machines on the market as the water must have a shut off valve or the water will keep filling the machine which is what it is doing, that is why I think it is the valve or possibly a loose wire but i am betting it is the valve.
    That is why the machine has a fill cycle, it allows the machine to fill and when the cycle is finished the power to the valve is stopped and the valve closes shutting off the water
    Hope this has helped you
  • Harry Goodwin
    Harry Goodwin May 25, 2009
    I am not sure if you are useing hot or cold water for the washing but whichever it is the hose for it will connect to the valve and then another hose will run from the other side of the valve to the washer.
    The valve is about 3 to 4inches long and the colour could vary but they are normaly white, will have 2 round ends opposite each other and about 4 wire connectors, take note of the wires and where they come from, write the colours for t he wires on a piece of paper with a little diagram of the valve and the places for the wires.
    I dont know which country you live in but I am assuming it is the USA
    Where they may make the things a bit different to australia but the machines should be similar in the way that they are set up
    Hope this helps you as without being there to look at it makes it a guessing game.
GE Super Capacity Plus won't stop filling
Does it stop if you stop the cycle or do you need to turn the valve off?
What is the complete model number of your unit?
Feb 17, 2013 | GE 3.2 cu. ft. Washer
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Samsung washer won't fill with water
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows then the flow should be good, if not the inlet valve is bad orthere is dirt in the filter. Also check the flow at the inlet of the waterline. Once the water comes into the system the WATER LEVEL SENSOR - normally apressure switch- must activate at the preset/chosen level to give the signal tothe program controller to switch on the motor. What is most important for themotor to start functioning is that the door switch must be ON when the door isshut or this will be an error for starting the motor for rinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jul 04, 2012 | Select Brands Washing Machines
Won't stop filling up. Water continues to flow without stopping for cycles
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Aug 28, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Not spinning or draining, only fills and agitates
the mixing valve in the rear needs to be repaced-it controls the water flow Also sounds like the clutch of the transmision maybe be a factor if the machine doesn't spin
Jul 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Won't run
Most washers today will not do anything after fill unless it sees the lid switch (innerlock system) closed. The same as having the lid of the washer up during a wash cycle. They will fill but until the timer, or ECB gets a signal back from the pressure switch (water level switch) it will go no further. Some of the electronic machines will also time out in the fill cycle because of a lack of water flow. The fill cycle is a timed event and if the water level switch ( controlled by the ECB ) does not close in the time alloted, it will stall. This can be checked by hitting the start button again. Most of these problems are caused by a lack of water flow on the initial start up. Cleaning your water inlet screens in the supply hoses and screens in the mixing valve itself will solve this issue.More information to the specific model would help pin-point this problem.
Sep 19, 2008 | Maytag LSE7806A Top Load Stacked...
Zanussi ZWF1430W Front Load Washer Logo
323 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
