Question about JVC LT-42X688 46 in. LCD HDTV
NO HDMI INPUT - JVC LT-42X688 46 in. LCD HDTV
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 105 Answers
1. Press "sleep" on remote so that "0mins" is displayed
2. press "video/video status" and "display" simultaneously to display service menu
3. go to "self check" menu. You need to go to "Digital Service" then "Self check" for some models.
4. Power off the TV while in self check mode
5. unplug tv then plug it back in
6. turn on TV and test the HDMI
Posted on May 22, 2009
  • Fabricio Sfredo
    Fabricio Sfredo Jul 24, 2012
    How can i do this without a remote
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
Can not connect to pc using d sub cable
Try to locate the video settings input their you will find the different function (video 1 input, video 2 input HDMI 1, HDMI 2, HDMI 3, HDMI 4), pc(RGB/PC, PC input). You can see the function in your remote.
May 16, 2011 | Televison & Video
I have my satallite on hdmi input 1 and my x-box on hdmi input 4. If I turn the tv on and tv's on hdmi input 1 all 4 of my hdmi inputs show that input until I change the input for my x-box to hdmi input 4...
I have the exact same problem/symptom. I suspect this is a very common problem only folks just now discovering it as we buy new hdmi devices. I called technical support and got the "sorry, out of warranty" talk. Mr Badge #74754 claimed that this was not a known problem. Would love to hear if others having this problem.
Jan 01, 2010 | Vizio VM60P 60 in. Plasma TV
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
RX-V465 output HDMI 1 will work but HDMI 2-4 won't, also when I hook up Wii via rca to receiver only get sound no picture.
This receiver has only one HDMI output, but 4 HDMI inputs. If some inputs don't work, try connecting the equipment (DVD for example) to HDMI input which works with other equipment....
For the RCA (composite) video input - it won't work, because this receiver don't have any video processing circuit.
So HDMI input video goes to HDMI outout connector.
Composite (RCA) video input goes to Composite outout and no other video output.
S-video input goes only to s-video output.
Dec 20, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Apr 22, 2009 | Yamaha RX-V663 Receiver
51F510 Input settings for HDMI
Okey,
Connect the hdmi, into the HDMI 1. that is automatically input one. Connect the 2nd device on Input 2, thats next to input 1 and hdmi, leave the input 1 empty, as the hdmi is connected to that.
3rd device into input 3
4th device into input 4.
Sep 08, 2008 | Hitachi 51F510 51" Rear Projection...
Hdmi input on pioneer pdp-r04u doesn't work. The component cables work, but not the HDMI. The digital audio works.
the r04u comes factory with hdmi DISABLED, hook up your hdmi device, and turn r04u to the hdmi  input (input 1 or input 3)  then:
To activate the HDMI terminal:
1 Press HOME MENU.
2 Press /  to select “Option”, and then press
ENTER.
3 Press /  to select “HDMI Input”, and then press
ENTER.
4 Press /  to select “Setting”, and then press
ENTER.
5 Press /  to select “Enable”, and then press
ENTER.
there you go
Sep 04, 2008 | Televison & Video
HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Sep 08, 2007 | Mitsubishi WD-52725 52". Rear Projection...
JVC LT-42X688 46 in. LCD HDTV Logo
520 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
