I have an LG HDD/DVD recorder RG278H, as soonas I turn it on the disc drawer opens and continues to open and close at random...help, it used to srop after a while and I could play a DVD but have just been sat here with it opening and closing for the last 10 mins.
  • gemolyneaux May 23, 2009
    Thankyou, will go get it sorted !
  • 6,784 Answers
Hi. there is a switch on the load bay that is connected to the motor/gear assembly. this switch has failed. it is no longer able to initiate the play/scan sequence. this switch sends a signal to the mother board that initiates the scan/tracking of the disc that has been inserted. due to the failed swicth, the board is under the impression that the dock is still in the loading process. this is confusing the motor as well, allowing the relay to flip continuously. you will have to send this player to Lg(zenith) for this in house repair. the dock and lens assembly are integrated so, the whole dock assembly will have to be replaced.
Posted on May 22, 2009
  • Michael Masters
    Michael Masters May 22, 2009
    The switch will also be replaced as well during the repair.
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
LG HDD DVD recorder RH7521W is not able to read the disc. It gives unknown disc error for all the discs. I tried disc cleaning cd also.
Mine had a similar problem. I assumed there might be some dust on the laser. I used an air compressor and pointed it at the DVD slot as it was opening and closing to blow some air around inside the unit (and hopefully dislodge any dust). It worked. The discs that would not play before did play after. I didn't have the air compressor nozzle too close to the opening as I didn't want to dislodge anything I wasn't supposed to. If it was dust on the laser, you might be able to clean it in other ways, such as removing the cover and using a cotton tip (take power off first!). That would have been my approach if I didn't have an air compressor.
Nov 08, 2009 | LG RH177 DVD Recorder/HDD Recorder
DVD TRAY KEEPS ON OPENING AND CLOSING CONTINOUSLY
Hi, I have exactly the same thing. Happened before but went away when I got bored trying to fix it. This time I phoned LG support and they said take it back to Comet (they have bought out their servicing). End of conversation. Polite but firm.
Appalling support via their websites, appalling products. Never again.
Oct 05, 2009 | LG DR787T DVD Recorder
LG RH2T80 DVD Recorder DVD slide is possessed! Missing Darcy
Same here, found one answer saying a power surge fried something on the main board. I'm still looking. Cheers
Aug 15, 2009 | LG DR-4912 DVD Recorder
Disc drawer says BLOCKED and will not open. No disc is inserted
I had the same problem . I had to take the outer casing off and was able to open. to keep this from happining again I always leave a disc in the disc drawer it seems to solve the problem
Mar 07, 2009 | Philips DVDR3450H DVD Recorder/HDD...
Bk. button
my relatively new, sat idle for two years, LG RHT398H DVD RECORDER has a strange fault the dvd keeps opening and closing at random if a disc is inserted and it wont obey open close commands, or read discs it, the dvd is totally rouge. The rest of the unit is fine. i think it will need re-install of firmware or maybe cleaning any ideas?
Oct 16, 2008 | LG Electronics LRM-519 Digital Media...
Dvd recorder - dvd+rw disc loaded - now stuck on load
turned off the dvd recorder at power outlet. Left overnight. Turned on again in morning and pressed open/close and managed to get the dvd drawer to open. No further problems
Jun 01, 2008 | Pioneer Televison & Video
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
