Question about Lanier Office Equipment & Supplies
LD245 Meter Read Help
How do you obtain a meter reading on this model???
"user tools"
"Counter"
Posted on May 28, 2009
Battery keeps dying
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. Clip a testlite to a good ground and touch regulator pin, if light glows replace regulator.
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Feb 09, 2014 | Harley Davidson Motorcycles
Voltage regulator
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
Jan 28, 2014 | Harley Davidson Motorcycles
Battery not charging
Jan 03, 2014 | Harley Davidson Motorcycles
Find charging dyna super glide 1450 cc
Nov 28, 2013 | Harley Davidson FXD Dyna Super Glide...
Low RNG
Nov 14, 2013 | 2011 Harley Davidson FLSTF Fat Boy
Battery keeps going dead
Nov 02, 2013 | Harley Davidson FXST Softail Standard...
My Harley Voltmeter pegs out at 16+ for hours of riding!
Hi Adeggert, perform the following tests:
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for drop in aprerage then get out your test light and track down the short in that circuit.
3. Make sure all connections are clean and tight especially the negative cable at "BOTH" ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v while cranking replace battery.
17. For a free wiring diagram please visit the website below. Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Sep 03, 2012 | 2010 Harley Davidson FLHTK Electra Glide...
Engine light and battery light
Hi Kellyafurlon, perform the following tests:
Jun 30, 2012 | 2007 Harley Davidson XL 883 Sportster
I have a 93 ultra when I apply the brakes all my gauges dump and the brake light stops working and the directional any help or ideas???
Hi Sargesmit845, perform the following tests:
Jun 05, 2012 | 2003 Harley Davidson FLHTC Electra Glide...
I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Apr 15, 2009 | Sharp AR-235 Copier
129 people viewed this question
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
