Vibration of the wash mashine
Wash machine has a huge vibration on finale stage of spinning almost jumping
  • Joe (AJ) Davis May 11, 2010
    Need brand and model, top loader or front?
  • 20 Answers
How old is the machine? Have transit bolts been removed? Older machine is possible bearing failure or spider breakage( a 1 in 10 wash with a temperature of 95 degrees celcius will extend life of a front loader!- an empty wash or towels or sheets at this temperature). A grinding noise can simply be a worn drive belt, rotating drum by hand and finding grinding and lateral movement equals bearing/spider failure. Also a simple case of Underlaoding the machine will cause unbalanced load and vibration.
Posted on May 23, 2009
Washer jumps and vibrates and makes extreme noise
Is this a new machine that you purchased and installed yourself? Or is this a machine that has worked properly and is now displaying this problem? If new, it sounds as though you may have not removed the shipping bolts that secure the drum. This would prevent the drum's suspension system from being able to absorb vibration during the spin cycle and cause the vibration to transmit to the machine's outer shell. If the machine is older, then the drum suspension system itself may need repairs.
Sep 16, 2014 | Washing Machines
Frigidaire fws747rfs1
The washer tub bearing may be defective, but that is the only thing that I can think of. Are you noticing this on all loads or just heavy items like bath towels and jeans? Are you redistributing the clothes before the final spin, try that. Also do not overload the washer, wash to medium loads instead of one full to the top load. Wastes water but saves on repairs.
Apr 12, 2017 | Washing Machines
Spin cycle loud vibration problems on spin cycle
What is the complete model number of your unit?
Dec 04, 2012 | Washing Machines
Washing mashine jumps around during the spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 25, 2011 | Kenmore Washing Machines
Washing mashine make a huge noice
Washer Problems
heatman101
Dec 30, 2010 | Washing Machines
FRIGIDARE FRONT LOAD WASHER,2+YRS OLD ON FINAL HIGH SPEED SPIN MACHINE MAKES LOUD VIBRATION NOISE AND FIND NEED TO SHUT DOWN DUE TO FRANTIC VIBRATION AND NOISE.
It is possible the bearings on the motor that spins the canister could be going bad especially at the high speed. This could also be from clothes getting unbalanced in the final spin cycle. Hope this helps. This could still possibly under warranty!
Aug 22, 2009 | Washing Machines
On the spin cycle my miele walks acrossed the floor
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 06, 2009 | Washing Machines
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
LG Fuzzy Logic
The load is "off balance"
check the vibration dampers are solid and the springs at the bottom of the tub are intact.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Maytag performa off balance
Check the vibration dampers and the plastic mounts for wear. They should be solid to the machine.
Jan 05, 2009 | Washing Machines
Washing Machines Logo
391 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
