Question about Philips Audio Players & Recorders
How do you wire a new mic to the Phillips FM1000 pmr Radio
How do I plug pinouts for a Phillips FM 1000 radio micraphone Please
SOURCE: FM without Earpiece
*#**372#
Posted on Apr 10, 2008
  • 313 Answers
SOURCE: dewalt radio. no fm signal
did you try replacing AA abttery at the battery compartment.if it is still not working the display board is cappot
Posted on May 27, 2008
SOURCE: Radio Wiring Diagram
Go to www.crutchfield.com.
On the bottom of the page there is a link for product support. On the next page, type "2005 Grand Prix" in the search box and hit enter. The top link shows an image and pinout on models with Monsoon sound systems, the second link for ones without.
Hope that helps! Good luck!
Posted on Jun 20, 2008
SOURCE: Mic wiring diagram
Want to wire cobra mic to a uniden washington radio
Posted on Mar 27, 2009
housejess
  • 317 Answers
SOURCE: bad reception fm radio signal
usually batteries...am takes less juice.....battery strength will affect fm signal strength
Posted on Nov 08, 2009
Need microphone wiring manual with pinouts for EA62x577 mic
you like others have no clue that without letting us know what kind of radio you are going to hook it to we have no idea what you want . A 5 pin cobra is totally different than a 5 pin realistic.
Sep 12, 2014 | Radio Communications
Galaxy dx 44hp, no am audio or mod ,fm & pa ok
Have you tried another mic. First guess microphone wire broke or broke solder for audio wire in mic jack at mic cord.
Mar 26, 2014 | Galaxy Radios DX-44HP Mobile Amateur Radio
Can a turner ssb+2 micraphone be wired to a ranger 2995dx cb radio?
If I remember right those mics were for relay switching radios and not transistor switching radios like todays models. Also I would bet you would be very disappointed with the results as the ranger radios have an excellent modulation circuit that does not need any help from a power mic. A trustworthy radio shop tech can tune up a Ranger and make it sound excellent without a power mic. I haven't installed one in years. They are a waste of money and time in most cases except for the D104 which can be used with some base stations.
Nov 14, 2013 | Radio Communications
Will a cobra power mic cure the low mod on my cobra 19 dx iv eu or will it blow the front of the rig
that is simply bs, Ham radio shops rarely like CB people (I am a long time cber and also a ham.
On that radio there are two things you can do, look for the mod limiter and remove it or another more simple thing:
This radio comes with a 1000 ohm element in the mic--like speakers---Get a older or new 500 ohm microphone and wire it or have it wired for the 19 dx, it will make a big difference in how it sounds.
I not only worked on those radios but sold them in a shop I owned.
You might find a used mic that's 500 ohm, it is usually stamped into the back case of a mic.
Dec 19, 2012 | Cobra 19dx Iv Eu Multiband Am Fm Cb Radio...
Trc 520 mic wiring dia
not sure what type pinout you have but if its a din plug any realistic mic should work.
Feb 22, 2012 | Radio Shack TRC-521 CB Radio
I'm trying to wire a galaxy desk mic to a cobra 200 10 meter mobile
  • The Galaxy desk mic (power mic) is already wired four pin and the Cobra 200 is a 4 pin already as well. So unless someone has messed with them the mic will plug right up to the radio as is.
  • But if someone has repined the mic then follow the pinout I listed below to get it rewired for the Cobra 200
  1. Pin #1 on mic connector - Black wire.
  2. Pin #2 on mic connector - White wire.
  3. Pin #3 on the mic connector - Blue wire.
  4. Pin #4 on the mic connector - Red wire.
  • If you look on the end of the mic connector it will have the imprint of the number for each pin on the mic.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 02, 2011 | Cobra Radio Communications
I need to know what colers go where on the mic pin for a trc 447 thank you
I don't know which mic you're trying to wire to this radio. The colors of the wires in the mic cable may change from one mic to another, so relying on the color is not reliable. Usually you refer to these connections as Pin1 to a Signal or Function; or Jack Pin1 to Plug Pin3. No one assumes a color will always be used to connect Pin1 to TX (transmit).
With that said, I found an answer on FixYa from someone that answered the question some time ago like this:
HERE IT IS THE CORRECT MIC WIRING FOR THE REALISTIC TRC 447.
1.)Audio
2.)RX
3.)TX
4.)CH.Down / Shorted to Ground
5.)Ground
6.)Ch.Up / Shorted to Pin 4
Be extremely careful when wiring this radio! pin 4 and pin 6 carry voltage shorting these to the wrong place can result in serious damage to your radio.
Lastly, since I doubt what was provided above is going to help you very much - you can review all the info ever printed by Realistic on your radio, here. There's a wealth of info on this page and you should be able to find what you're looking for in it. You're looking to find the pinouts of the radio to the pinouts of the mic.
If you ever have to disconnect a multiconductor cable from a connector, and you don't have the time or means to write the colors down, it is better to simply cut the cable - leaving all the colored insulation of wire ends soldered / still secured to the connector. When you are ready to do the replacement of the connector or cable, you've got the wiring order in place still, and can make the new connections one at a time at your leisure.
Aug 11, 2010 | Radio Shack TRC-447 CB Radio
Have new dx959 doesnt get out very far talking 100yrds or so use rdking 56 mic mic works fine on old radio pc 78 and gets out fine also are 959 radios ok or junk has good reception
The DX959 has an output power setting knob. It's located next to the channel selector and is labeled RF Power. Turned counterclockwise will reduce output power. Turned clockwise will increase output power. Your switch is probably turned all the way counterclockwise resulting in low transmit volume.
Also, make sure the wiring for the RK59 is correct for the Galaxy. Even though it's a 4 pin plug, the pinouts may be different for the Uniden and Galaxy radios. Do a Google search for mic pinouts for your two radios to check.
Jul 12, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Wiring diagram
Hello birdhunter, no the cobra 200 has the same pinout as the 29's and such, but the color code might be different.
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
STOCK Pinout Let me know how you get along with it,,,, Mechanic
1- Shield
2- Audio
3- Transmit
4- Receive
Sep 14, 2008 | Magnum DeltaForce CB Radio
399 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
