Question about GE (PSS26MSRSS) Side by Side Refrigerator
Drain tube gets clogged
The drain tube on the freezer side of my GE side by side backs up. This causes ice to form on the bottom of the freezer and eventually leaks out onto the floor. This seems to be happening every few days. I have followed the directions in my service manual and poured warm water with baking soda down the drain. However, I can only get a small amount of water to go down before it backs up. I seem to be unable to get the drain tube totally clear. I have made sure thc coils are clean. What next?
  • butch w May 24, 2009
    water leaking on floor under freezer door
  • 11,896 Answers
I suggest using a sink snake. After the clog is out, then use drano or equivelant.
Posted on May 22, 2009
ICE FORMS IN FREEZER BOTTOM,
Keep the bottom of your freezer free from ice. ... The water from the melted ice and frost drains through a short tube and into a pan beneath the refrigerator, where it evaporates. Should the drain line become clogged, the water has nowhere to go and it freezes, forming a layer of ice in the bottom of your freezer.
How to Fix an Iced Freezer Bottom ' Home Guides ' SF Gate
homeguides.sfgate.com/fix-iced-freezer-bottom-42777.html ICE FORMS IN FREEZER BOTTOM Google Search
Oct 23, 2017 | Refrigerators
Ice forming at bottom of freezer
I had a problem with Ice forming in the bottom of my freezer on my whirlpool side by side freezer-refrigerator. Turn out to be a plugged drain in the bottom of the freezer. That drain goes into a tray under the whole unit. During Defrost, condensate drops from the contents of the freezer on to the bottom of the freezer and goes through a drain tube to a pan underneath. Should that drain tube become plug and the water is left standing in the bottom of the freezer, it will turn back to ice after the defrost cycle is over. Once the drain tube is clean out, the problem goes away.
Oct 20, 2014 | Whirlpool Refrigerators
Ge profile refrigerator model number tfx30pry
You have a clogged drain system in the freezer, as the unit will defrost daily, the water can't leave the freezer properly and the water collects. You need to de-ice the freezer and clean out the drain tube at the bottom of the freezer section under the evaporator. Good Luck
Jul 20, 2014 | GE Refrigerators
Bottom of the freezer keeps filling up with water and freezing solid. eventually leaks thru the door onto the floor. It takes 3 to 4 weeks for it to form thick enough to eventually leak thru the door on to...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | GE GSS25JF Side by Side Refrigerator
GE freezer (side by side) if forming ice at bottom of freezer. The problem is unrelated to the ice maker and water feed (have them turned off), and appears related to the heating element causing water to...
There is a drain that should be visible just beneath the heater, it may be embedded in formed ice block. The drain is likely clogged and can be cleared by using a turkey baster with hot water to force water through it unto the pan underneath.
Jun 06, 2009 | GE GSL25JFR Brushed Steel Side by Side...
Ice build up bottom of freezer and water on floor GE Monogram
I had the same problem. The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. I took the sheet metal cover off the back, got a turkey baster and flexible tube, and continuously flushed hot water (after the freezer had been turned off around an hour to thaw). Eventually the plug gave way.
Apr 09, 2009 | GE Monogram ZICS360NR Bottom Freezer...
I have ice forming in the bottom of my freezer section of my GE Profile side by side refridgerator.
probably have a clogged drain at the rear base of the freezer unit check at the very bottom of your freezer at the back look and see if the drain is covered with ice..
Jan 15, 2009 | Refrigerators
Where is the drain pipe located in the side by side profile ge
in the back at bottom in freezer there is a drain hole which may not be seen due to ice but remove the ice and clear with hair dryer or hot water / larry
Dec 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
428 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
