Hot air blowing from AC
My AC is blowing hot air. I think I need to add freon. Can you tell me how to do this on a 2000 Olds Alero?
    Novelist:
  • 166 Answers
Yes, so as not to be repetitive (as others have had the same problem), here's a simple article that percisely explains the possible causes of your AC not cooling:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Also, if it turns out to be a need for a Freon recharge, how will you get the Freon? Freon is not sold to the general public. Like it or not, Freon (the refrigerant used for AC's) is highly controlled, as it is supposed to be sold only to licensed AC technicians.
If you feel you need a technician, don't get ripped off with a quote fee, by the way; take advantage of the above link towards the end for four free quotes from technicians if you find yourself needing to get one. (You don't want to needlessly be charged for just someone's coming over only--it could cost a lot for no substantive action.)
Brad
Posted on May 25, 2009
My 2000 Chevy Tahoe front ac dosnt work but rearworks blows hot air
Sounds as if you have more than one problem. If the rear is blowing hot then the AC is not working. The front should also blow hot if the front fan motor is functioning.Youi need to have the system pressures tested for proper freon levels and have the front blower motor system tested if it is not working
Jun 28, 2015 | AC Cars & Trucks
My gmc yukon 2000 slt rear ac blows hot air when i have ac . on and the front works fine .
I have a 2000 GMC Savana Van SLT with front and rear AC/Heat. My front would blow hot while the rear blew cold with AC on. It turned out to be low on Freon. It's hard to know if you have the right amount of freon installed because pressures vary depending on the ambient temperatures. So the best way is to remove all the freon then reinstall the recommended amount as listed on the evaporator housing near the firewall. This worked fine for me... works like new after installing the correct amount of freon.
Jul 01, 2014 | 2000 GMC Sierra
The ac is blowing hot air the freon charge is good but the ac still blows hot air whats the problem with my 2000 chevy silverado?
Is the compressor kicking on? If not and the pressure is in the normal range then I would say that the low pressure switch is stuck. It is located on the canister right beside of where you hook up the freon. Unplug it and cross out the plug and see if it starts then.
Jun 11, 2010 | 2000 Chevrolet Silverado
My sisters olds alero is overheating. What is the
Take a heater hose off and start it up, it should push it out, a lot, like 10psi pressure. Is the cooling system clean? not rusty?Does the heater blow hot air when the engine is hot, if so thats good. when the cooling fan comes on, is the air coming through the radiator hot...it should be. if not, the radiator may be stopped up. if the top and lower hoses are hot, but the air coming through the radiator is cool, the radiator is plugged, and will need to be taken apart and cleaned by a radiator shop, or better yet, replaced.
Oct 15, 2009 | 2001 Oldsmobile Alero
2004 MALIBU MAXX A/C BLOWS HOT AIR
Could be several things. The fuse relay to the AC compressor could be bad. The system may need to be recharged due to lack of refrigerant the compressor will not work unless it has enough.
Jul 19, 2009 | 2000 Dodge Neon
2000 dodge ram pick up - ac blows hot air and freon is good
expansion valve looks like is not openning or the capilary tube is bad
Jun 26, 2009 | 2000 Dodge Ram 1500 Truck
Air conditioning problem
sounds like not enough freon or orfas valve is clogged. but most likely it is low on freon
May 05, 2009 | 2000 Oldsmobile Bravada
Car ac blowing hot air
pls the qty of freon is depending of the size but you can not add freon any time since no leak so chek may be
- thermostat
-hot water coil is on
- selector on heating
- compressor is defective or the clutch or coil
- low pressure swith open
-high pressure switch isopen
Apr 21, 2009 | Heating & Cooling
Cant find the low pressure port to charge a/c on 2000 olds alero
It should be near the compressor on the low side line. It is a huge pain to get to. Feel along the line, and you should come to the fitting.
Mar 05, 2009 | 2000 Oldsmobile Alero
Heating & Cooling Logo
248 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
